Snap Crackle Pop!
hyrum Utah.
Went wheeling this morning. Broke my pinion flange! Snap!
I was giving it a lot of gas trying to make it up a loose rock/snow hill. I came up over the top with my front wheels in the air, I came down and POP! I snapped the pinion flange, and sucked the driveshaft down under the truck!
Now I've got to wrench on it to get it ready for more wheeling tomorrow. I'm hoping that I can get another flange in there with the dual bolt pattern and try to squeeze my FJ60 shaft in place.
Wish me luck!!
Are you *sure* that you just broke the pinoion flange and not the end off of the pinion????
An FJ60 driveshaft will not be the right length to fit in a '40. A double carden front shaft from an early '60 will fit in the front end of a 4 speed '55, and it works the other way around too. But that's it for interchanging shafts between Cruisers.
Mark...
Just got in from the garage, mounting flange for yoke broke, driveline tacoed. Pinion flange bent a bit. I have a 350/nv4500 conversion, so stock drivelines wont work, but my flanges have both bolt patterns. The FJ60 shaft fits, but my spline engagement is only about an inch! I work in a machine shop, so I'm running in tonight to see if I can stretch my old one out.
Cant miss wheeling tomorrow! It's with other Cruisers!
