Smokey
The Ghetto
Sometimes when I start up my SBC 305 I get white smoke from the exhaust....it's not that profound tho. What's up with that? I cleaned the carb a couple weeks ago, sealed up some header leaks, plugged all the vacuum spots on the carb. I'm not 007.....what's up with this S***?
Howdy! That's commonly referred to as cold smoke, as it never happens when the engine is warm. It usually means that some of the oil seals on the valve stems are getting old and cracked, and they let a little oil leak down the stem into the cylinder where it accumulates very slowly and then smokes a little when you first start it up. It usually does not get worse very quickly. It has virtually no effect on performance or smog testing. John
I vote valve seals as well. You may notice as time goes along that if you sit at idle for an extended time and then gas it you get the same smoke. Cheap fix on a V8 Chevy.
You can replace the valve guide seals without removing the head using the string trick. :D
Condensation. The hot exhaust gas going through the cold pipe causes moisture to build up and then steam off. Are you noticing that you need to add engine oil between changes, or are you adding coolant to the system? If you are not getting a blue color at start up, then you are not burning oil, and if you are not adding coolant, then it is only water vapor and not anything to worry about.
