Does anyone have any experience with sliders compared to shackles? I've read a few threads on them else where and wanted to see if anyone regrets converting to them. What's the ride quality like also?
liquidironindustries.com
forum.ih8mud.com
Huh I was wondering what happened to that guy. I liked his build, but I guess he didn’t like it here. Oh wellThis 40 has them up front:
Build - Frog's 40
forum.ih8mud.com
There is an ex-member here (got pissed off, threw a fit, deleted all of his stuff from the forum) that had them front and rear on an FJ55 with 54” springs from the rear of a 99 GM Tahoe SUV, and claimed it rode like a cadillac.
This is his truck in this thread:
CA - Liquid Iron Industries leaf spring sliders
Title is it. What have you got on the shelf for that project you changed your mind on? PM me a cost shipped to Georgetown, CA. I can come off hill to Auburn or Placerville sides. Since everyone likes in use photos:irate4x4.com
Two benefits I see to them:
1. Lower ride height
2. Protect from bending a leaf spring by bashing it into
Downside I see:
Less flex due to limiting range of motion and less leverage on bushings.
Threw a tantrum, took his toys and left the sandbox.Huh I was wondering what happened to that guy. I liked his build, but I guess he didn’t like it here. Oh well
forum.ih8mud.com
Likely only benefit to slider style is lower ride height. Never used those style shackles (revolver or double shackle) but they would allow far more droop and flex of your suspension if shock lengths and other common interferences accommodate.I’ve never heard or seen them before. What is the benefit of these over the Teraflex shackles?
When they first came out they were headed for the mount of droop you’d get Then the naysayers claimed that thee extra droop was unweighted and therefore useless. No expeirence, just what the internet rumors said.Likely only benefit to slider style is lower ride height. Never used those style shackles (revolver or double shackle) but they would allow far more droop and flex of your suspension if shock lengths and other common interferences accommodate.
I don't know if I buy those arguments. "unweighted"? Gravity doesn't care, its going to pull down on that axle regardless of how its attached to the frame, how its attached will dictate how far it will droop. A properly setup suspension should utilize a bump stop to transfer force from the tire being compressed to the tire that is drooping to help increase droop and traction.When they first came out they were headed for the mount of droop you’d get Then the naysayers claimed that thee extra droop was unweighted and therefore useless. No expeirence, just what the internet rumors said.
That is an interesting opposition. I’d wonder though if the tire approaching unsprung weight really matters whether it is flexed more because that tire is either touching the ground or not at that point, but wouldn’t the opposite side of the vehicle have more tendency to be better planted?When they first came out they were headed for the mount of droop you’d get Then the naysayers claimed that thee extra droop was unweighted and therefore useless. No expeirence, just what the internet rumors said.
You said this better than me, and you hit “post reply” quicker, too.I don't know if I buy those arguments. "unweighted"? Gravity doesn't care, its going to pull down on that axle regardless of how its attached to the frame, how its attached will dictate how far it will droop. A properly setup suspension should utilize a bump stop to transfer force from the tire being compressed to the tire that is drooping to help increate droop and traction.
Like I said, I have no experience. I was intrigued when I first saw them, but not enough to get some. Everytime they pop up in conversation I listen to what people say. At best they seem a mixed bag, but personal experience may vary. They look neat.That is an interesting opposition. I’d wonder though if the tire approaching unsprung weight really matters whether it is flexed more because that tire is either touching the ground or not at that point, but wouldn’t the opposite side of the vehicle have more tendency to be better planted?
I didn’t know that, to bad he had interesting stuff on the go.Threw a tantrum, took his toys and left the sandbox.
I can understand. We all have our breaking points and the community in this channel seems to be quite a bit more welcoming on average than the other channels. I’m afraid of auto check removing the “40” from “FJ” anywhere else.
Thanks for sharing these shackles. I’ve never heard or seen them before. What is the benefit of these over the Teraflex shackles?
Teraflex Shackles - Any one using these?
forum.ih8mud.com
I know this a thread on spring sliders but figured I'd add my opinion on the revolvers here. My cruiser has had the revolvers since the 90's (before I was born) and I even recently grabbed a set that was still new in the box off of craigslist to replace my 20+year old ones. The main issue I see with them is that they almost allow too much travel. The "arc" that leaf springs allow the axle to travel seems exaggerated. An example would be when one tire is almost completely drooped out it is halfway under the rocker.I don't know if I buy those arguments. "unweighted"? Gravity doesn't care, its going to pull down on that axle regardless of how its attached to the frame, how its attached will dictate how far it will droop. A properly setup suspension should utilize a bump stop to transfer force from the tire being compressed to the tire that is drooping to help increase droop and traction.
