Sliders Added - Ride Compromised - Solutions?
Hey All,
I recently added OPOR sliders from Metal Tech to my truck and the ride is noticeably stiffer now. The truck really transmits much more road feel and vibration to the cab. I'm not very happy about that and had not anticipated the change.
Currently I am running a TJM 50mm lift with TJM's non-adjustable shocks. Would moving to an adjustable shock solve this problem? It seems like having softer shocks might help, but I'm not entirely certain about that. Any other suggestions? Taking the sliders back off and either not running them, or installing them only when I'm going wheeling don't seem like practical solutions. I bought them, I want to run them. And storing them and installing them for wheeling trips would be a pain, and would surely result in less wheeling.
Share your thoughts, please.
Thanks
Russell
Sliders should not affect ride at all, or if anything, make it slightly softer due to the increased weight. Are the sliders touching the body or pinch weld anywhere? If so, adjust and re-tighten. You should have at least a 1/4" gap between the sliders and any part of the body. Otherwise, I can't imagine why sliders would cause what you are experiencing.
:edit: If they're not contacting anything they shouldn't, I'm going to go ahead and say your problem is something else and the fact it happened at the same time as your slider install is pure coincidence.
Take a look and see if you have some small rocks n gravel between the sliders and the rocker panels. Makes a lot of noise but you can usually knock them out with a long screw driver. John
Sliders most definitely stiffen the frame. I've noticed the ride become stiffer on all 4 vehicles I've welded sliders to.
I can't visualise how a slider will 'appreciably' stiffen the frame of an 80. It's already a boxed chassis and the sliders only mount along the partial length of the middle (not even where the suspension/axles sit). I could be convinced of some overall stiffening if there were cross members added, but a long piece of metal that mounts with 3 or 4 relatively long outriggers will make so significant difference.
You are adding some weight (maybe 50 - 70lbs per side), but that tends to make the suspension cycle smoother if you already had stiff springs.
Adding/removing a few psi to the tyres will make a LOT more difference.
Maybe adding the sliders increases the 80's self perception of manliness and that increased vehicular testosterone makes it 'stiffer'...
cheers,
george.
The TJM in rear is a progressive coil, by adding weight you are getting into a higher spring rate which is why you are feel a more firm ride. A single rate spring will feel softer as weight is added.
My $.2
Placebo effect or not, I feel that the same sliders made my rig more rigid. YMMV
I recently added a set of White Knuckle Off Road sliders and I swear I'm experiencing the same thing.
U guys are all freaks!!!!
I have installed many sliders on rigs in the past an never felt a change in ride quality
Although I do have the same OPOR sliders bolted on my 80, and the drivers front arm does rub on the pinch rail and it still vibrates at highway speed, however, not enough to make my lazy a$$ unbolt it and bend the pinch weld up
I've read this is or was a pretty common problem with the OPOR sliders, dunno if the guys at MT have remedied the issue or not.
Thanks for the feedback guys.
I must say I'm amused when people "like" contradictory information in a thread. Landseer, I'm looking at you. ;)
Been a while since my structural engineering courses but increasing your second moment of inertia will increase your stiffness...no? Weather or not you can actually feel it is something else for sure.
They have Not..! Bolted my IPOR sliders up a month ago, same Issue you have Johnny. I sence no change In the feel of my Rig, I here an ocasional Tap on the pinch seem..! Shim Install Is on the horizon. :)
My $.2
My vote. If the springs aren't linear, the first inch compresses easier than the second. Added weight gets you closer to the higher rate at go. Seems likely to my noggin.
I just like to go wheeling..... :meh:
I have TJM 50mm progressive springs and OPOR sliders also. Like many said the effect of the slider was very subtle and it helped smooth out the ride a little.
Question here is how much weight do you run? If you have lots of weight then adding more weight definitely can worsen the ride which requires you to get heavier springs.
I have very little weight. No fridge, drawers, no rear seats, not much weight at all. I just took my tire pressure down to 32 psi, hopefully that will help. I was running 38 in hopes of getting a bit better mileage. I'm driving from Ventura to Joshua Tree this weekend, so that's plenty of miles to see if it helps.
