OK, this brings up a question: If I want to install this bumper, what type of lift would I need to bring it back up to stock height or a bit higher. I would like to go to larger tires.... nothing drastic, but a bit larger and those will be purchased and installed in Aug '09. I am not as much of a rock climber as Shotts is, but I would like a bit more clearance.
That's a whole 'nother subject however here I can say that you shuld swap out T-bars to heavier-duty ones in order to support the new added weight. You can set them for the same height or add lift. Then you could add lift to the rear to match.
