Slack in driveline
New Mexico
When Shifting in gear from park I have noticeable slack in driveline. Sometimes a soft clunk sound and jerk. Probably ujoints? Is this common theme with fzj? What are the possible culprits?
What year?
Have you checked the front drive flanges? Mine did the same thing and they were shot.
might be normal might not depending on PM and mialage. I would start by climbing under it and checking "normal stuff". Then start doing PM that needs to be done anyway if there is any. Service bifieilds and check everything while in there. Then pull drive shafts and service them, probably needs it as most our rigs do if we have not done them recently.
that will bring you up to a good baseline PM and fix the common cheap drive line stuff before you dig into the diffs or anything.
I had a little bit of clunk going on a few months ago and after shooting grease into the zirks on the drive line it went away. Reminds me I need to get back under and make that happen again, the past week the clunk is coming back.
I would have started off by paint match marking the slip yoke and removing it to check for spline wear. Then packed the slip yoke with grease since using the zirk fitting doesn't really do anything. Then check all the joints for slop. If your joints have slop after greasing then replace them. It would be wise also to check the pinion and transfer case flanges for slop.
When I installed part time hubs on the front axles, I found a lot of my driveline slack went away, so X2 on the drive flanges.
Ordered about $800 worth of fixings from cruiser outfitters today. Thanks mct75
Wow, that's a bold move if you hadn't been under there with a greasegun yet.
I had a 'thunk' of sorts in the old 450, but did a new rear driveline / pinon bearings when the ARB's & 5.29's went in, so plenty changed.
Did fuel mileage increase after mod?
birfs starting to click so it's money I was going to have to spend regardless is this doesn't fix the clunk.
It's been winter, so they've been locked for the most part since they were installed. I didn't do a full part time mod, as I refuse to give up AWD, so even when unlocked at the hubs, everything is still spinning, no fuel economy increases are expected. It does drive differently with the front hubs unlocked though.
A couple shots of grease will do wonders on these Drive lines. Do (all) of your u-joints and slip yokes (easy on the yokes, just a few pumps) and you'll notice a big differance.
