Skyjacker 4" not really what I expected.
38.0111,-109.9181
Website
www.alamosa.fm
Had some 4" skyjacker lift springs from a LONG time ago that I never installed. The springs are now on the 40 and the rear sits SIGNIFICANTLY lower than the front. I don't have the bumper measurements, but I feel like a redneck with a full-size truck with rear end dragging after a lift.
Anyone had similar experiences? They're on stock shackles, so I can correct the rear a little bit with some lift shackles.
Also, there's just no way these springs are 4" lift. My old springs were REALLY flattened and I'm just not that impressed with this supposed 4". Is it just me now years later trying to get a 40 looking good when I've been so used to 6" lifts on 80s?
i really haven't been impressed with skyjacker. they have always seemed to be too stiff and not sit very level. you can try to use lift shackles, but don't try to get more than an inch or so of lift with them imo.
i have the skyjacker4", mine is level.
they ARE stiff when you get them. but only 4 or 5 years later and my are quite supple..... after about the 3 year mark :(
Are you absolutely sure you don't have them installed in the wrong end? The fronts have way less arch than the rears. And they are about the same length. It wouldn't be hard to do. I have their 2.5 inch kit on mine and the back sits higher. Just a little bit, but with an aluminum tub and no hardtop, that is to be expected.
i loved em when i had em...if they weren't 4", they were damn close cause they made my 33's look tiny. this was with old rock basher reverse shackle kit and 2" shackles in the rear
Well, the springs were marked with a `F' and `R' unless they may have been labeled wrong upon purchase? I'll take some pictures, hopefully before Thanksgiving as I'm gone, and post 'em up.
The markings were like IIRC "LFRS40" and "LRRS40" or something to that nature.
I and several of my pals run Skyjacker 4" lifts. Each one of us had the same issue with the rear sagging. A couple of us had it sag so bad the shackles flopped up against the frame in the rear. Our solution is what you alluded to: extended shackles. 5-6 years later and no issues. The other thing we learned is to use a different shock than what comes with the kits. The old Warn Black Diamond shocks were a favorite of ours but I don't know how the current Black Diamond shocks compare.
HTH,
Nick
Yup, got LONG shackels on the rear of mine and stock on the front and it sits jsut a touch high in the rear. The springs are pretty soft now that they have years on them too.
Had soft ride's from skyjacker on my mini and hated them, not sure if it's the same issue, but the rear sagged a ton. I sent them back twice and had them warrantee the springs. they just went flat after a about a year each time. They have measurements as to the unsprung shape and were good about the warr. I only had to pay shipping for the worn out ones back, but I still don't think I would own another set.
I have OME springs now and love them, (2.5" and SOA). They seem to be the perfect spring rate for me, but the $$. I got em cheep and unused from a guy who put em on a rig and never finished the motor swap.
I've been running the 4" skyjacker springs on my '71 FJ40 for 6 years or so with 1" longer shackles front and rear and it sits pretty level. As someone mentioned, it took a few years of good offroading for the springs to soften a little. With the hard top on, my 33's look a little small, but with the top off it looks great. I don't remember what the measurements were before and after, but it was pretty close to 4 inches as advertised.
I guess we all have our own opinion but mine have been great. I have had them on for about 7 years and they haven't sagged. We just installed some 4" HFS on a buddies truck with the same size tires and they are exactly the same height. The only thing different is I have the stock "cruiser lean" and he fixed his on the new spring install.
Later,
Later,
you should start a thread with some pics of that hfs lift. they seem to be rising in popularity, and i'm hearing a lotta people asking about them.
I have the skyjacker in mine (or so I have come to believe) and I can't stand it. Too stiff and the rear sits close to an inch lower. I guess I can give em a chance but if it doesn't get better by the time I have the money for a bigger suspention then it's gonna be GONE! Want either SOA'd OEM or SOA OME :cheers:
