SKid Plate design
Utah
I am designing a skid plate for my FJ40 and I have a few questions.
I had a 4x4 shop lookt at my truck, and he was going to put in 2 new cross member, reroute my fuel and brake lines, and drop the belly down. I also got the impression that he shop wasn't really interested in doing this job
so I am designing and building one myself.
My plan is to get something like the Trail Gear slider plate and gusset kit, modify, then bolt the "L" shaped plates onto the frame in the stock skid plate mounting locations.
The kit I am looking at using runs 3/16" thick plates.
After getting the "L" plates bolted on, then I would measure and have a piece of 1/4" steel skid plate cut to my dimesions.
I would weld this skid plate to the plates bolted to the frame, and then trim the "L" shaped plates
I would then put on 4 gussets per plate to make everythign strong.
Does anybody see a problem with this design? I do realize I would be loosing a bit of clearance (I don't have alot of choice as my t-case hangs down about 2" past the frame). However, I would be getting a flat belly plate.
would the 3/16" plates suffice, or should I look at 1/4" plates?
Also, what about the option of putting some bushings between the plates and the frame itself (the red in the pic attatched)?
Thanks!
look real beefy
probably would skip the bushings,
i got a few ideas ive been tossing around.
call me
looks like a good plan to me..
i would not bother with the Bushings, but i guess it could cushion your truck when you drag it across a rock. ;)
id think 1/4" would work well!
see post 3. this dude's got it going on.
Thats a nice skid plate for sure.
I don't have access to a pressbrake to be able to build one like that, though.
tiger your desighn is good, simple and managable for the everyday person.
i would stick with it. like myself i have to get creative since i lack the sweet tools some have. i wanna see it when your done
I am designing one very similar to what a guy named Jesse Crews did, as shown on page 38 of the March 2007 issue of 4 Wheel Drive and Sport Utility Magazine (not affiliated or recommending, I just bought cuz I liked some of the ideas on the Cruiser). This is also the same as some of the work I've seen done by Lance at Iron Pig. Removable skid plate that incorporates lower cross members that can be used to mount a shackle to for the traction bar.
I bent a cross member I had installed behind the t-case (cut original out for conversion) with my tract bar - so this solution kills two problems for me.
Basically uses two cross members bent from roll cage tubing welded to 2" angle iron mounted to the frame. This allows me to run a flat spot on the drivers side and only bend around the bottom of the t-case in front of the drum brake and at the front output shaft (I don't have the tranny to worry bout as I have a 4.5" AA adaptor that can also be used as a 3rd support mount. Then just gusset an apply your favorite thickness of plate and you're good to go.
I'm going to use 1.5" 3/8" wall square tubing and cut and reweld instead of bending the tube. Hopefully with the lateral gussets between the cross members in addition to the flat plate, it'll be plenty strong.
that is slick i was thinking along the same lines but with square tubing since i dont have a bender.
use square tubing and cut it and weld it, same just not as clean as bends.
My plan is to bolt the plates on up-side down, then weld the skid itself to those pieces.
My main concern here is if 6 3/16" plates and 6 M8x1.25 grade 10.9 bolts are going to stand up to use and offroad abuse.
I also have a bunch of 2x2x1/4" wall square tube that I could build this out of as well, but it would be EXTREMLY heavy.
The 8-7/16" grade 8 bolts that I use to secure mine through the frame get beat up to the point of replacement once a year.
I do not think that the stock 8mm diameter fastener, even in a 10.9 grade is going to live long in that application.
