Simple adjustable LSPV MOD
Groveland MA
Website
landtankproducts.com
I think I posted this a while ago, maybe three years now but couldn't find it so I thought I'd do it again as a member is dealing with this now.
What I did is to make an adjustable extension to the LSPV arm that attaches to the axle.
needed supplies:
1/2" tubing found at Home depot
1 - 12mm bolt
1 - 12mm nut
3 - 12mm washers
Basically you cut the tubing to a length taht is comparable to the amount of lift you have.
Then using a 12mm tap thread both ends of the tubing.
Now thread the nut onto the linkage at the axle and place one of the washers on top of it.
Now thread the 1/2" tubing down on top of the washer
Now put a washer on either side of the arm and thread the bolt through the arm and into the 1/2" tubing.
To adjust just loosen the bolt and nut and rotate the tubing to move it up or down the linkage shaft to effect the rear pressure.
On lower lifts the bolt and linkage can hit inside the tubing and restrict it's ability to move down. So use the shortest bolt you can find at the top and if need be shorten the linkage some to make room.
Attached is a very rusty mud soaked pic of my setup. An adept searcher might find the originals which are a lot clearer in how this was done.
Very nice. If you have 3" of lift, you cut the tubing to 3"?
I recently found that adjusting the LSPV at the frame was sufficient to account for my lift. In fact I think I overdid it and went through a set a rear pads in 30k miles (right through to the backing :whoops:). The front pads are still fine with 40k on them.
The details are somewhere on the board. Just another option.
you would have to play around with it as I did this a long time ago.
one thing to remember is that the axle link originally goes through the arm so when you add the tubing it's now under the arm so you gain some length there.
With a 3" lift I'd probably start with a 2" piece of tubing.
One thing that is nice about this is if you raise the truck by 3" you can then extend the length of the linkage by that amount and be real close to where you should be.
got a link?
The problem I found with that is the lspv arm started to hit the upper control arm. That was my first attempt at correcting the lspv.
I can't believe that no one has removed that POS and posted it here. Someone? ANYONE? Done this yet? There are several manual valves I'm sure you can incorporate to fit. Just seems like another weak link that needs to go. I would also think it would effect your braking when in the rocks.
Do a search, there are some threads that discuss this.
anyone have pics of how it should look like stock angles and such of the arms im gona try and do this mod on a 6in lifted TLC 80
The best adjustment for the LSPV with lifted trucks is to get rid of the stock unit (which I did) and get a manually adjustable one that conforms to better bias when you are weighed down for expedition and when you are not and are DDing it.
I am using a Wilton model that has metric fittings. One in, one out. You will have to get rid of one of the redundant lines going to the rear (or leave it and bypass it).
-o-
Beno, could you be more specific on what you did with the extra line. I've seen it under there but didn't understand what the heck it does. I want to get rid of my lspv also because my seems to be frozen. :confused:
Let me preface this by saying that I am not advocating nor am I endorsing modifying your brake system one bit. There are legal issues involved....
That said, I used an OEM brake T (part # 90413-10058) (the same one underneath your master cylinder) and T'd the two lines coming into the LSPV with the T instead and have the one line going out to the rear calipers. The LSPV acts as a T considering there are two going in and one coming out.
I am basically trying to mimic as much as possible the brake line set up of the earlier 80 series without the ABS (but with rear rotors) because this is basically what my system now resembles sans the LSPV and with a manual line in the engine compartment.
I'm going to do a thread here since some people have PM'ed me about this....I just have very little time these days to sit down and do this. Hopefully in the next couple of weeks I will take care of a LSPV removal/maunal PV install thread.
Good luck.
-b-
