Simple adjustable LSPV MOD
I worked with another member this weekend on his brake system. He had a soft pedal and wanted to check it out. What we found was that air was entering the system somewhere and was only showing up through bleeding the LSPV. Bleeding the rear calipers never showed any air what so ever.
From this I figured that the LSPV is more than just a simple "T".
Beno, I'd be interested in any insight you have on how this system works. One line that goes into the LSPV goes back to the ABS actuator and the other goes back to a "T" right below the MC.
From bleeding my brakes it also seemed that the LSPV bleeder was bleeding a separate line as I had already bleed the rears completely and there was air in that line after that.
I got rid of the LSVP on my minitruck with a manual "kit" from FROR (~$100). It did abandon a few lines and simplify the system as a whole, as well as obviously the bleeding procedure. The only thing I don't like is having to adjust the system fro different situations (i.e. fully loaded when going hunting), so I don't make adjustments.:)
However, based on my brake wear patterns, my LSVP on my 80 seems to be performing well. FYI, I only got rid of the LSVP on the minitruck because I boke it while servicing the truck...:doh:
In my searching for more info on the LSPV, I found that our trucks have a Load sensing proportioning an bypass valve. It is not the typical mini truck LSPV.
Our LSPBV is way cooler. Landtank has unwittingly shown how it can save your butt while wheeling and on the highway. On his trip back from NC, he lost only his front brakes due to a cracked line. Well after reading, toyota designed the system with the rear hydraulic brakes to still work if the fronts are lost to a complete line failure, really cool safety feature. Our LSPBV will isolate the Rear hydraulic brakes if the front hydraulic pressure is lost or too low. IMO, don't replace the stock unit with a manual unit it would be a bad idea. A manual proportioning valve is a step back in terms of safety and design. Toyota got this one right, keep the stock unit and adjust it properly.
Want the word from toyota's mouth? Follow the link http://www.autoshop101.com/forms/brake08.pdf to pg 13.
Good luck.
Good luck.
You can still get this redundancy with a manual PV if you mimic the early non-ABS 80 series brake system routings.
-o-
-o-
but that would mean gutting the ABS actuator. Do what you want but if I was in an accident where a fatality occurred I would not want to have altered brakes on my vehicle. Especially one that is so apparent that it has been modified by just the lift and tire size.
The ABS box is now a door stop in my house.
if abs has been disabled (like it has been on my one ton build)n could the lspv be used as a proportioning valve? could it just fix it in a certain position and act just like a proportioning valve?
where is the abs box so i can remove it and make a doorstop too?
It's on the DS front fender just behind the fuse box. It's the thing with the brakes lines attached to it.
Personally, I would get rid of the stock LSPV and get a manual unit where you can control bias front and rear. It's a guessing game, really. You have to load up your rig and try different speed stops to see where you need the bias.
That said, once you have dialed it in for different loads you can easily put it to where it needs to be later on. Basically the PV biases pressure front to rear...either increasing rear pressure or decreasing it.
I have gotten enough PM's regarding interest in this to where it is best to start another thread regarding the removal of the ABS box, routing of new lines (mainly mimicing the non-ABS earlier 80 series), placement of T brackets, and the placement of the manual PV. But again, I forewarn with a disclaimer--the FZJ80 is an ABS vehicle and is listed as such with insurance companies. Please modify your brake system at your own risk. I am not liable for any one else's mistakes...read Rick's post above.
I hope to get around to this in the near future.
-o-
needed supplies:
1/2" tubing found at Home depot
1 - 12mm bolt
1 - 12mm nut
3 - 12mm washers
Rick,
Is the tubing 1/2" inside diameter? I was looking over lunch and couldn't locate what I needed. Of course, I hate looking for anything in Home Depot.
Rick,
LOL I'm not sure, probably outside. It's in the hardware section where all the small pieces of square, flat, angle and round stock is.
I'll go check again. I thought it was outside diameter, but the way my day's been going, it was smarter to doublecheck.
Thanks!
I have in my hand a M12-1.75 hex nut. When I crawl under the truck to see if it will fit on the rod for the LSPV adjustment, it is so big, it simply slips over the end of the rod.
Am I on crack? I have a 12mm hex nut, do I not? I understand the threadpitch *may* not be right, but this thing is so much bigger than the rod I'm trying to thread it on that there is no engagement.
The nut on the rod fits a 14mm wrench. The M12-1.75 nut in front of me takes a 19mm wrench.
Like you said, I'll pull a nut off (man, this doesn't sound good) and double check.
To set the rear proportioning valve, there is a spec in the service manual, and it also "delays" the rear activity, by more when unloaded, so as the front brakes activate fully before the rears when lightly loaded in the rear.
If you hvae allowed air in the system, you will always need to bleed at the prop valve, as the air wont come all the way through to the rear, it will stay at the highest point dow back, and the fluid gets around the air.
Wearing out rear pads before fronts isnt uncommon on toyota 80 series, but the acid test is to try braking mid corner in slippery conditions, or gravel, and ensure the rear isnt going into massive oversteer while doing so.
You can also make a wire template of the rod position when lifted by the amount at the diff, of the lift, then bend the arm near the valve, so it replicates your wire template at your new ride height, but we suggest making a template of the standard shape also, in case you need to return it to std as a default setting, in case you get it wrong.
