Show us your rear work light (2 Viewers)
Sydney, Australia
Hey all,
I would like to install some sort of work/reverse light.
My tints are pretty dark, and at night, I cant see anything in my reverse camera. I want to install some sort of small light bar in the rear mainly for this. I would like it subtle..I dont have a rear bar/wheel carrier, just the standard.
Thanks everyone!
SacTown!
Thinking about getting another one of franks antenna mount and put a work light on it.
...Misspelled via IH8MUD app
flat earth Midwest
SNIP... I would like it subtle..I dont have a rear bar/wheel carrier, just the standard....
The subtlest install is to replace the OEM bulbs with high intensity bulbs. Looks exactly like stock and no new wiring needed.;) I don't recall the brand name/part number for here in the US, but suspect it may be different than what you may have available. Maybe someone will recall? That's what I'm running, although I suspect you're looking for something to really light things up back there.
By now, I would think a high intensity LED replacement/upgrade would be available, but I haven't heard of any. You might try simply crossing the bulb number against a LED lamp list to see what comes up.
BTW, nice truck!:grinpimp:
Tell us more about that rear hitch. We get just a plain ol' port-installed hitch that's just a hitch. Yours looks "improved" -- looks like might be a good place now to get a Hi-Lift jack under her if needed, maybe recovery points, etc? It also looks like it tucks better under there than our port-installed hitch.
Southern Maine
I got a cheapie little
60 degree LED flood light on the roof and 80 watt LED reverse lights. No complaints with either one.
Between pixels
This is what I got, but looks like with your spoiler it's a no go. I find the brightness (72W LED) just barely adequate with the factory Lexus tint. It's wired into the reverse circuit with a relay as well as a manual override switch.
Sydney, Australia
Awesome..thanks guys...I dont know about those...they dont seem too subtle..Where can I get that mount from, and what size ligth does it hold?
The Wing is the OEm from Japan I imported myself.
The rear "Hitch" (We call it a tow bar lol) is from Hayman Reece. Pretty much the main Tow Bar places in Australia.
http://www.haymanreese.com.au/
This is pretty much a factory fitted bar.
Oh yeah, I have upgradedthe Bulbs to LED, to be honest what I had before was betetr!
Caracas, Venezuela.
I simply have a rigid dually (diffuser lense) mounted on a tab in the spare tire carrier.
No offense, 98_snake_eater, but I would much rather have two wide beams as opposed to 6 spots. . The lighting would be MUCH better and the amp draw much less. Although given your amount of lights (in this setup and the previous one) you dont seem to care in the slightest for amp draw.
I think even my single Rigid Dually is even better. Maybe not as intense, but more useable without a doubt
