Shock & Lift Question
I am attempting to replace my front axle seals with an SOR kit and I thought I might replace the front shocks at the same time.
From the picture, can someone tell me what was done to this front end suspension by the PO? What is stock and what is not?
The shocks measure 16" eye to eye and the shackle measures 5.5" bolt to bolt. How do I determine what the lift is? What sized shocks do I order (OEM + ?)?
Any other observations or recommendations would be appreciated. I am looking to improve the ride and I do not do any serious offroading.
x2 on the shackles th more verticle (longer) they get the worse the ride becomes. but then again your not driving an escalade here.
As flat as the springs appear to be, you are probably good with the shocks you have, unless they are worn out.
GL
Ed
Hi All:
Greetings "Mudpup!"
What size tires do you have on the rig? (don't look too big from what I can see in the pic.)
Your FJ40 sports a "Saginaw" power steering conversion and longer than stock length shackles in the front; the front shocks appear to be stock length.
What are your plans for the rig?
Regards,
Alan
Alan,
The tires are 31 X 10.5. While I am replacing axle seals, I am looking for any cost effective improvements (under $1000) I can make to the suspension to improve the ride and/or offroad capabilites (no rock crawling).
I had the power steering installed right after I bought it.
i happen to have a used one im geting rid of, see for sale section, everything is included
