Build Shipwreck
I'm still smiling. A DNR volunteer came to me in the parking lot, he drives a pretty sweet rig, and talked to me about mine then said "that is the best rig there is here at Walker" dang.... made me :D
this rig
I'm 90% sure that guy lives not far from here. I recognize the vehicle from my drive home.....
everyone needs 2 soft tops for their FJ40, right? how about if I mentioned it was cheap (like ridiculously) and came with the doors?
and seriously, if anyone needs this (it doesn't have the frame and is a Best top in tan) - let me know. As far as I can see, the windows are okay, there's a slight, easy fix cut by the door.... I bought it because it's cheaper than a tarp and has matching canvas doors.
Next time you head to walker valley? I can meet you down there whenever.
yes, but it may be awhile.... I have not-a-chance-I'll-get-to-Walker-Valley stuff going on from now until sometime in July. Point is, if you want it sooner, you may need to come get it. I think you have my phone number, but if not, I'll PM it to you now.
Sounds good, price is good, and something I can definitely work with. I'm not in a hurry!
Here we go....
I don't have the picture but it looks like new hubs will be part of this build....
and a hard picture to take but it almost looks like there's cracks in the face (on the wheel side, not the rear).... going to inspect closer tomorrow - was hoping the digital picture would help me see... maybe it did?
the knuckles
moving forward
knocked the studs out, then decided to buy new ones.... so 2 day wait for that.... but got forward
so easy with the right tool
might as well lube the upper ball joint
all apart and waiting on the studs
back to this.
the decision is I'm going to use the parts of this, but attach it to the the tow points - it's just not what I want, so making something new is the better choice
also bought some spare wires
the problem, there is wear where there shouldn't be wear
basically, I think I was supposed to cut 1/4" off the stub shaft and put the circlip on the inner ring
see the two cuts? I think the outer one needs to be cut off
of all 4 major pieces, this is the only one that is undamaged
and there is breakage inside... probably because the hub was full of aluminum from the wear
the short of this is I think (going to check with Carl at Nitro tomorrow) I didn't shorten the stub shaft.... but since it's darn hard to add splines back, a phone call will happen before the chop saw happens.
I may, tomorrow, go to Olympic and get a couple parts - while I'm at it I may see if I can't piece together some new-to-me hubs. These hubs are a hybrid and still not sure they work for this application.
Hub assembly
press the new studs in
then press the pins in
it's funny, growing up, my dad (still owns) owned a sheet metal fab shop and has a 200 ton 12' press brake. We never had a hydraulic press....
front reassembly
if anyone is doing this - do not put the high steer arm or studs on before you attach the hub
and a problem
I put the panhard mount in the way of the cross shaft... oops
I have most of the parts to move it... only thing I don't have is the threaded bushings.... not just that, but I don't like the heims on the panhard so I'm going to replace those with something lined and lubable.
so there's the steering connected, if I must, I can get the truck off the lift - that said, I want to finish this before I do.... the biggest problem now is the panhard is no longer parallel to the steering arm (bump steer issues arise from that). With that said, this is going to make this even more of a joy to drive and, bonus, allow me to turn sharply when a wheel is stuffed
and I'll put the shorter arm back on to quicken the steering
a good view of the next things I'm fixing
thanks for following
I think I know what happened to the hub. I should have figured a way to put the lock on
as you can see, the 2nd ring isn't visible but the 1st ring is almost too far out. Fortunately there is a fix, cut the inner shaft down a bit
time to fix the panhard
cut and move back
in no particular order, pictures
a fun treat was every single bung was frozen solid to the TREs..
high angle TREs (note the notch?) - yeah there was one issue.
so I'm waiting on steering parts, tomorrow I'll finish the panhard and maybe get working on the seat belt bar on the cage.... presuming I can find the rest of the belts...
What's next is finish the front then redo the exhaust. I love having cats on it, but it's causing fuel heating issues with the fuel tank. Last time I was wheeling, fuel vapors were boiling out the filler. I think the solution is going to be several layers. I have quieter flowmaster mufflers - I'll take this and put them under the floorboard (that moves them forward to where the cats are). On the floorboard, I'll put dynamat (on top of the ceramic coating and on top of the bedliner...
the issue with the cats is they reburn the exhaust which causes the temps to go from 400 degrees to 700 degrees (inlet/outlet) and into the muffler - that is right under the fuel tank. The mufflers have exhaust paint that's breaking down because it's too warm.... ah well, somethings work; others, not so much
and to foreanswer - the batteries are under the floor in the very back, I could make a tank for the space but then the batteries would be above those temps; also, the space is smaller now because the axle is further back then stock so the capacity would be pretty limited.
checking clearances
like this clearance
fixed
line up, clean up
weld up
and it fully turns
one of the big reasons for this effort is to get a better turning radius at full stuff.... once I get the parts for the high-steer cross shaft (probably Thursday), this bit is done then onto all the other stuff
