Would it be the 80's tech forum if there wasn't a lot of over-thinking?![]()
Its good to a point but it has gotten you no where at this point
Just move the damn axle already!
Just move the damn axle already!![]()
Yeah but...
Why spend $5 on a couple pieces of steel....
When you can spend hundreds on a new radius arm?![]()
I can pilot a set of my plates to shift the axle forward by about a 1/2". Not what you are looking for but add that to what kidglove13 did and you can get what you need.
Something nice about lifting a 37" tire with (almost) 14" of travel. Little hard to see, but the tire is almost completely below the rockers.![]()
Completely redesigning the front suspension is far out of what I'm interested in. Seen too many people start off saying their going to do a complete redesign, and "it will be completely streetable." Few months/years later you see them posting "hey, anyone got a trailer that can pull my 80 to <insert run here>." Or they sell it. Or they quietly go back to the original setup.
I think that you could probably redesign the suspension and have it streetable, but I also know I don't have the skills to do so. Since this is my DD, I have to set limits, and not messing too much with the basic design is one of them.![]()
Your right side tire looks good - the hitch pin mod may be giving you uneven flex side to side or your body mounts may just have the body a bit uneven over the frame.
I would do the plates - take LT up on moving the axle forward a little bit and fix your caster at the same time.
I didn't realize you had a hitch pin in there that you are pulling. Because of that I'm going to retract my offer.
Pulling the front bolt allows that side of the axle to shift on the arm the same way may caster plates function and effectively shortens that side's arm.
12mm is the magic No for 37's.
Who makes the 12mm product?
If I had to guess, you do.
We will seeYou wont be saying that when you get hung up on them all the time if you wheel you truck
If I had to guess I would say you are wrongWe will see
yep - pricey but available over the counter Offroad 80's • Auto Craft 80 Series Products
