shackles
Length? Braced? Unbraced? Use?
I make my leaf spring shackles from 2" wide x 3/8" thick steel bar stock. I usually make the pin spacing 5" (stock is 2.75"). Overall shackle length is usually 3" longer than the pin spacing. So a 5" pin spacing will end up an 8" total shackle length. I drill the shackles for 9/16" spring pins and because I do not have stock LC springs or shackle hangers. I sleeve them with 0.75" OD tube because I use Chevy spring bushings with an ID of 0.75". To finish them off, I round the corners.
Yup just get some flat bar and go to town : real easy
Unfortunately I've never had anti-inversion shackles... braced shackles seem to limit articulation somewhat. That said, I've got them in the rear.
