- Joined
- Feb 8, 2004
- Threads
- 294
- Messages
- 5,760
- Location
- Cloverdale B.C. Canada
- Website
- www.instagram.com
Found an old pic of one of my my oops. Won’t be doing that again.
Old pic from years gone past. I was cruising down the logging road heading for home probably a bit quicker that I should be ,when all of a sudden I came upon this small washout. Hit the brakes most likely nosediving the crusier then the suspension dropped as I flew and dropped into the shallow washout . Cycling my driveshaft to far and it separated,dang. Flopped around under the rig and went bang. Jammed into the leaf spring Shock area. Bent the leaf spring and snapped the bottom shock mount off. I got out to access the damage and found my shaft laying on the road.
Not fun. Unlocked the hubs tossed the shaft into the rig and limped it home. Fun day it was.
Or it happened when I launched out of the washout. I can’t remember. Twisted off the pinion dented the drive shaft tubing.
Note to self build a front driveshaft with a longer slip joint when running a shackle reversal.
