setting up drum brakes
City that rhymes with fun
im currently in the prosess of redoing my front drums. i have new cylinders and shoes. ive never dont this before so i was hopin to get some tips on adjusting the cylinders for intial set up. any tips and tricks are greatly appreciated. thanks friends
i usually adjust them and then try to fit the drum over, then adjust them and try to get the shoes as close to the drums without touching it. putting in new cylinders in is cake you'll get the hang of adjusting them and you'll quickly notice if there is any drag... just remember how everything came off so you know how to put it on right and do one wheel at a time so if you sit there and say " where the hell did that go?" you can pop the other wheel off and have a look and see how everything went together.
ok just to make sure im clear here.... say im doing the front cylinder on the driver side i want to be turning the adjusteraway from the axl. and if im doing the back one on the same wheel ill be turning it towards the axl?
to tighten, always go away from axel - whether on front or back. so, if on front cylinder on drivers side, you pull the screwdriver or drum adjusting tool away from the truck, pulling, away from the axel. always use the axel as your reference relative to where you are and pull away from it to tighten.
only time you go towards the axel is to loosen.
In my case - it was 10-15 clicks before I had the drums so tight I could not turn the wheel and then I pushed the tool towards the axel to loosen it and the wheel spun free.
and techincally - you are not really 'turning' anything in the sense that you might turn a lid on a jar with your hands, you are more ratchiting and pushing or pulling the tool/screwdriver which in turn then 'turns' a gear inside that makes the adjustment. the concept of 'turning' something confused me when researching the topic as that was the default word people used, but it is not really the acurate motion you would be doing though your motion does result in the something turning inside the cylinder.
awsome man, i thought it would be simple like that. you just made my day
great... glad I helped.
read that 1-5 steps on that link above I already mentioned as it is helpful - and that was my first time also. :) it was much simplier than I expected. hardest part is getting around the leaf springs and shock mounts on some of the cylinders - so a short tool or driver is best. I made my own from a shorty screw driver as I found the actual spoon tools too long.
well its all been said before when i was trying to get parts to rebuild my drums.
To adjust my drums, I use a caliper to set the outer width of the shoes to be within ~1/8" of the drum ID. No dealing with put it on, adjust, wiggle, take off, adjust, wiggle BS. One shot and its done.
ok so now it seems i got another problem goin. first i have the new cylinders cranked all the way in and thye seem to drag just a little. also when i push the pedal to engaged the brakes the cylinders seem to stick in the drums they dont release very quickly!!!! what is causeing this????
well, if this is the case, did you follow the process of backing them off 5-6 clicks as recommended by Toyota manual? That will stop the drag as you do not want "the new cylinders cranked all the way in"
I am not sure on this, may be an issue related to the above step. do the above step and see if this issue continues. I assume you are running the vehicle when this occurs or atleast have the engine running to engage the power brakes?
backing them off 5-6 clicks from where half way out or all the way out. power brakes. its a 67 im pretty sure everything is manual.
yes i know this, but the cylinders dont seem to be releasing very much after i take my foot off the brake.....
They don't have to back off very much, and that's all done by the springs. You don't have a power brake booster behind the master cylinder? If you do there's other things that could give you a little trouble.
If not boosted, and you can still rotate each wheel after letting off the pedal I wouldn't worry about a drag until I'd driven the truck a little and then tried them again on jackstands.
it seems when i apply the brakes they fully extend and do not return in. could there possibly be air in the lines? they extend so far the boots come off.
You don't want to do that with the drum off. :eek:
And, you don't want to do it with the drum loose, either. You can get a rough setup with the drum just attached with the set screw, but the best way to adjust is with the wheel on and all (or at least 3) lug nuts torqued down. Slight skewing of the drum will mess you up when you try to set it up and then go back and tighten it down with the wheel. You want close tolerances so you don't have to push the pedal far before the shoes contact the drum.
the wheels were on the first time i did this. i got them adjusted all the way down now and am goin to rebleed the brakes tomorow. ill start from square one from that......
That sounds really strange. If they are properly assembled and adjusted the pistons only move a tiny amount. Starting from square 1 sounds like a good idea, but this would include making sure that everhting is properly assembled. This does not sound like a bleeding problem.
