SeldomSeen 76 FJ40 rebuild.
What are you planning to use this Cruiser for? I’m not sure how I missed this thread, but I’m always intrigued by someone who wants to extend their Cruiser.
All covered in the first post. :D
Offroading, rock crawling.
I more or less want to make the FJ Cruiser the Toyota should have given us.
I may compromise and keep it SOA, though I am very seriously considering linking it.
Worked on making a stand for the cowl so I can move it around and work on it.
Couple of Updates.
I pulled the front floor. It's in OK shape, I could patch it, but I am pretty much on track for 3/4 tub replacement.
Heres the tub off of the frame.
It looks pretty rusty, but I don't see any rust through.
The rear crossmember needs replacing and I need to rework some of the welds from my rear SOA spring mounts.
RIght now, I am looking for some pictures of how/where people extended the frame. I was thinking about cutting the frame about 6" in front of the Spring Hangers there (where the tubular crossmember currently is, I know that needs to go if I do an H55F), but I want to see how the taper of the frame is handled with doing a stretch.
Kind of thinking that I'd cut the frame, patch in a couple pieces of box section and then brace/cross the frame with cross members in those spots.
If your stretching the frame I would wait until you get your tub before you cut. It looks like to me that between the crossmember and spring hangers is about where I would cut. If you are stretching the tub, I would do a LS to 4l60e or 6l80e to whatever tcase you want.
I'm toying with the idea of 2UZ->A750->AtlasII
I am not certain if there is a way to go A750 → Split case.
At least, not without trying to source unobtanium parts (A750 → Toybox → Splitcase)
