Second opinion needed
Sandy Utah area
I have a compound issue on my 97. A coolant leak started yesterday from what appeared to be behind the timing cover. T-stat area and water pump area looked dry but I could see coolant running behind them onto the ground.
S_7ddaVbhKk91nQEuVffSxrGiD3hP4mY0KDZHq2z_9sIw5ojE6Uii07LIrQbDFwha7PODGbRL-oGOOXgU7dsZhKcn8bIfL-XaKmwS_BIH3itdDMmzHsNao43bSYmmF5hwMlPqLu7XOht7Dn6MS42Dd0RUQonY7dNKFkwFwcldqbF_Z7AotKTa-TRuMLHDklPcmDGuCGeA7sx_KwQDhB6ww3sdIAteUvXq5UbgB2Zftp1-1IWBF58KpgNyyu7DkyeuMHI14r-Bz7Md75gTYh5Jo8tiaBRh4Dh4XL22Vl3LBdED27b6k3p05oWKBDklvN12qdvO2W9p75KEPD_rL1kBwTQqJs1Cmp237dweSt3aBqcpgwYj7rswI34kyAgjV0HlcwPthTuxchdCiLP7Wlbj1Z50sZUol09ZdQp3vceC4MjcxI1KQUcz5hDu9W7Lqgjs0qsPHmolXesKmXhdRxbKuTmMRXKzoE_LtcIYP4N4MDHqtN-by3S39V7AU5Y6Z8ir6BnXIN0rxxuUXSrwOzzz5V-YnL5mptvViiy7XuGITi7skK9ZL5WlCojG_vEcf8lRDAkknDf4aPOqx2i9Gc9J1MtgoPaO19JFhyea7nD9yw=w821-h1094-no
Additionally, my timing cover is CAKED with oil and it wasn't that long ago I cleaned that area.
-Yc22q3-uZMQ4eKgUsDP55RwHO33EmR3SUHSLKRaLA8FLRwCC8f2WHpio8_BrvEZjePzODwv14PKqzaVTWhrM4wllM6xaQzhiUoa3jpSM3d-IuQl97K4ndHPhEQU_r6xlrBhpnUEjOQcYcllX_6P7VBV6jPfKWTTtyqMrk5jC_5909UNTIV08kWgZMIfWS0iHsc0xfChzyVNB6HKodsSaimmBwgLrBi5WFCpWiWRNhsOvi00KVSKIhqFKZwMWKMQk_skWj51iWpOao7WM6qV8nEYO6wE5Z8R3eHNGy1-TAQByVxTydUs1p5nnG8JbPWeOBPSrEhsR6I3JEtVyeIFVp6XNl_vn2XS7Yp1mo_IbMGGFtjotEyzYLMIDlDC4kZP5s0eBMqrrlJcTS2Hyk7aiN8eCtYGooqMuXCdxlnqWRQjPLsm2SEfdsvG7vJpJV1zgPgMIIr6_ma8UTvGFRq6IjS4fCZwKf7qZlPjWKpIQ4awrV_tXnDoait6JPzWLJUL2JeTU0eIzvkcD5Tz7C7PD9rDrWQnZWnNcvFZqMYBuFW7EmeC8-GwnefHLWxVlXimFukspQ8Xg_b5eMy5kwKDqBOqlns84e9IVpxB7mwpSpk=w1459-h1094-no
I took it to State automotive here in Utah and they found that the radiator (4 years old, oe) is seeping and a hose in the back of the engine is seeping under pressure but nothing out of the area i described. They also noted the huge oil leak in the timing cover. What worried me is that 5 years ago I had the head rebuild so the timing cover shouldn't be leaking like this since they would have (presumably) done the entire gasket set.
Question -
What coolant passages are behind the timing cover?
is is possible that the passages are leaking and forcing oil out?
What are my options here aside from pulling the head again?
What the story on the radiators health if its seeping from the top and bottom where the aluminum crimps?
EDIT: Bad radiator and leaky front timing cover are the culprits. bummed about the leaky cover but its livable.
If rad is seeping change, I d look at the water pump too see if it's leaking, there is no coolant behind timing cover, there is a pipe on the pass side that has two prints that can leak coolant
Whats your opinion on the timing cover leak? No biggie?
Are you sure it’s not the oil pump cover that is leaking? Typically the timing cover and oil pump cover seals are not replaced during a HG job and are not included in the gasket kit IIRC.
I know the oil pump cover gasket was replaced, they also did the front main. See state told me the front cover is included in the kit but I didn't think it was
I would wash the engine and see where the leaks reappear from.
Thats the current plan, they put dye in the oil to see where its coming from.
Cleaning the area & adding the UV dye would have been my $.02 too.
Identity the liquid & move forward accordingly.
I never saw mention of dropping clean cardboard under it & going that route to identify, might do that at home to see if above & beyond the dye you see something too.
Also, I had multiple 1/2 cans of degreaser when I went to the local coin-op wash to clean a used trans for my Camaro, the 'foaming' -type clings longer & you get more bang/buck from it.
Bored & standing there drowning a 700r4 in it, had my own little 'Pepsi challenge' - HTH too.
I think maybe the engine cooks the seals and causes them to leak after a period of time? I might have 80k miles since the last time i resealed the front and have the same mess as you from the oil pump. I have new seals and just waiting for better weather and time to go through it again.
Pro tips for DIY car wash engine cleaning:
Bring safety glasses, rubber boots, a few cans of brake cleaner or degreaser and don't hit the distributor cap or top of valve cover with any pressure. For some reason the cruiser requires this more often than any of my other vehicles :)
@hammerheadfistpunch the front of the timing chain cover looks like every cruiser I've ever looked at once the oil pump seal starts to leak. It's so incredibly common that I always mention it when people are looking to buy. I have replaced them on all four 80 series that I've owned. It's not a difficult job, especially since you are going to be draining your coolant system anyways to deal with another issue. You might as well make your life easier and pull the radiator for better access.
UPDATE: So its definitely leaking out of the timing cover, I see dye on both sides of the cover and in multiple places. and the real kicker? Its for sure leaking coolant from behind it as well.
image-jpeg.1310050
There is a coolant passage at the bottom left of this picture (top left of the cover looking at it on the engine). Thats where my coolant is coming from (thanks nut430 for the picture). Pretty sure this is another side effect of using Divinity. This makes the last of their repairs I've had to redo. I had them rebuilt the top end, wanna guess what they didn't do while they were in there? Yup, remove the cover and replace these seals. So now I need a new radiator (not sure why but its leaking) and figure out what to do with this coolant leak. REALLY not looking forward to another top end job. To the point where I am looking at 100 series. I hate stuff.
