I have a compound issue on my 97. A coolant leak started yesterday from what appeared to be behind the timing cover. T-stat area and water pump area looked dry but I could see coolant running behind them onto the ground.
Additionally, my timing cover is CAKED with oil and it wasn't that long ago I cleaned that area.
I took it to State automotive here in Utah and they found that the radiator (4 years old, oe) is seeping and a hose in the back of the engine is seeping under pressure but nothing out of the area i described. They also noted the huge oil leak in the timing cover. What worried me is that 5 years ago I had the head rebuild so the timing cover shouldn't be leaking like this since they would have (presumably) done the entire gasket set.
Question -
What coolant passages are behind the timing cover?
is is possible that the passages are leaking and forcing oil out?
What are my options here aside from pulling the head again?
What the story on the radiators health if its seeping from the top and bottom where the aluminum crimps?
EDIT: Bad radiator and leaky front timing cover are the culprits. bummed about the leaky cover but its livable.
Question -
