Screw In Funnel
@Steamer I like…where’d you get it.👍
Perfect, thanks. Just ordered.
Should still work with a 2f.
Maybe, but Im going with something between not well and poorly.
We will see in a day or two.
Should your experiment not work to your standards and feel you might want to trash the funnel.....give me a PM. My 2F's VC has a screw in cap that it might work on. :hillbilly:
None the less, I have one in my cart already.
Just went to the Amazon questions for this product. Someone asked if this would work on a 1974 LandCruiser. The answer was YES.
Did not say he had a F engine but I would assume so. We shall see.
EDIT: correction, the question was for an F engine,
Question:
Will this fit a 1974 Toyota Land Cruiser?
Answer:
Yes it fits 1974 Toyota Landcruiser 3.9 L6
autopartssupplygroup
Seller · January 18, 2023
Yup, that was me. I guess the key words are "screw" in.
I got "THIS" one for the CRV. Fits good also.
Just ordered "THIS" one for the GMC. I'll be color coded now.
Just checked and the Toyota one fits the 2F in the 83 60 also.
do not recommend for the smooth bore 2F valve covers...the OD of the funnel is roughly 0.375" smaller then the ID of the oil fill, the length of the engagement portion is pretty short as well.....would work if you keep one hand on it at all times, otherwise it's barely self supporting when empty.
it also does fit the 1FZ-FE as intended.
Just received mine & it fits perfectly on my ‘86 2f with the threaded oil valve cover. Will make oil changes a bit more sanitary.👍🎯👍
Just used mine today…excellent. I was pouring in oil from a Delo 2.5 gallon jug. Still had to hold it, but it was much easier & did not spill a drop.👍👍👍
i just roll up loose leaf paper like a fawkin peasant
up side... it fits all holes, you control how big the funnel end is and costs like 1/2 a cent :beer:
custom funnels :meh:
