Build "Scout" the 1977 FJ40
4 degree caster shims make this drive like a Cadillac!
This little adjustment makes driving Scout such a pleasant experience. No more bump steer and it tracks down the road with ease.
How long is the installation process? Need to do this. Guessing it's a quick evening project.
Hey Emanc,
Hope you're doing well!
It took me about an hour. I used a method that I think works really well and takes some of the effort out of it but requires two sets of jack stands.
  1. Lift vehicle and put jack stands under frame.
  2. Remove wheels and put jack stands under hubs supporting the axle.
  3. Remove ubolts from one spring, remove front shackle and lower spring.
  4. Secure spring with c clamps on either end of pin
  5. Remove spring pack pin
  6. Install shim, fat end facing front of vehicle
  7. Reinstall spring pack pin
  8. Put it back together and do the other side
  9. Tighten ubolts up install tires, test drive and retorque ubolts
I put this off for a few years only because I didn't fully understand how much of a difference it would make and secondly because I was avoiding the task. Turns out it made a huge difference and was far easier than I made it out to be in my head.
Thank you for the wealth of info on this thread, spent a couple hours reading through and enjoyed it all! Your build is exactly the kind I'm looking to get into. Currently looking for the right 40 to buy.
Thank you for the kind words. It's been a really fun build and now that the 4 degree shims are under that front axle it sure does track well! My wife and I took it for a spin last weekend and I'm reminded at how solid this vehicle is. It's also very quick... not very fast but extremely quick.... for what it is.
I really like the stance of your FJ40. Mine is lifted 2.5" with monster shackles and it looks RIDICULOUS! What shackles do you have?
Thanks so much! Great question, I didn't put them on but I believe they are the older OME anti-inversion shackles. That's a mouthful. I believe they are the older ones with the flat spot that prevents them from inverting because the ones I tend to see now have the pin rather than the flat spot. I also think they're OME because they had a sticker on them which was similar to the one on my 60 which I know are OME.
These look like them, but I'll measure pin to pin for you if you'd like.
The stance works out well. It rides really well and doesn't have the "disconnected" feeling that the longer shackle lifts tend to have in corners.
Not nesessary to measure but thanks. This is what mine look like. I don't like lifting vehicles in general. It creates a litney of problems. I am going to go back to close to the original stance. I just have not decided on which shackles and I will probably get new springs too.
If you feel your rig is sitting too high, it might not be a bad idea to simply start with the shackles. I mean you're going to end up replacing them at somepoint and not only will it give you a great starting point but often times it's 40% of the work when replacing springs, so putting new shackles in will help make the spring replacement easier when/if that time comes. If that makes sense....
Great thread and read.
I about pooped my drawers when you casually walked into a frame off resto…
Honestly, I thought, see you in a couples years scout. 68 days I think you said and most of that waiting for the t-case. Insane.
Now over to your 60 thread.
Ian
@77CruiserDog What new with Scout?
Funny you should ask @EWheeler , I've decided that in a few weeks I'll be putting together a classified ad for Scout. It's been an absolutely beautiful journey but Scout is ready to move on to a new family. PM me or call me if you're interested. I will need to do a little research to figure out a price but feel free to shoot any questions my way. Sad to see it go but we're buying a new home and won't have as much room, plus if I'm honest, it's more sad seeing Scout sit in the garage for months on end... someone needs to drive and appreciate it. Let the next journey begin!!
Cheers,
Adam
206-817-6788
Cheers,
Adam
206-817-6788
Sorry to hear you'll be selling Scout, but I completely get it. I'm considering selling my "nicer" 40 purely due to lack of indoor storage and just having too many vehicles in the fleet. I really enjoyed both of your build threads, you are a master at eating an elephant one bite at a time, but really fast. I'm not a buyer, but some lucky cruiser head will end up with a completely dialed in 40! I hope you get all the bucks for it!!!
