SCORE! (finally)
It sure sounds electrical to me. I would think the failure would have been pretty violent if the engine siezed. Take a look at the harness behind the EGR and see if it's melted. That's a quick and easy check. Heck it could be something as simple as a ground.
My alarm will flash and blink after the battery has been unhooked. I have to hit the button on the remote to reset it. I can put the key in and try like hell to start it but nothing happens, no noises at all from the starter. You might check into that.
IT STARTED!!!!!!!!!!!!!
Got the new battery in, and the key fob stopped all the flashing (Thank you 85Badger!).
Not all good news, it definitely had some bad noises coming from the engine bay. Sounded like a loud knocking/chirping, and then it shut down forcefully. When I turned the key again, it started again. Definitely could be bad news, but it also sounded a lot like my water pump did when it seized. At least we have made some progress. Going to take off all the belts and see if any of the accessories are seized up.
fingers crossed for you
Rev it until the noise stops.
This might actually work. I know of four different cruisers that have sounded like this after sitting a while. Two were mine and two belonged to good friends. All four of them came back to life and quit knocking after some running and driving. I think the problem may have been the hydraulic cam chain tensioner but that was never confirmed. I've also had a couple that the noise didn't go away and those ended up being rod bearings. Anyway, either the motor is bad or not so it may go away or it may throw a rod through the block but eventually the noise will stop if you drive it enough. Maybe listen to the knock under the truck VS above the engine. If it's obviously in the bottom end, it's probably toast, but if not I'd drive it around the neighborhood and see what happens.
lol @ Italian tune-up remarks. I would believe it if it were a 2f :o
If it's the chain tensioner(and this does make some sense), that part is an easy two bolt removal to check to see if it's functioning right. The ones later than 1994 had a ratcheting mechanism vs a sliding spring deal. That part could get hung up if it sat or it got hammered around somehow and isn't pushing against the slipper properly. I would remove that part and see how it looks and replace it if it seems suspicious(I just bought one from beno for $22 for my '94).
I would do that before just gunning the motor.
Motor is toast. Rebuild it.
What if it's not though? I thought my head gasket blew and what really happened was that my rear heater hose blew and all the symptoms lead me to believe the HG blew. Now, I am not upset that I am doing that project, but if I could have fixed the heater hose for $12, I would have had more time to plan things out.
I would take the chain tensioner out and wiggle a screw driver against the slipper to be sure it is keeping the timing chain in the right spot. If nothing else, by doing this, he might be able to salvage the top end rather than ruin the cams and all of the timing gears which would make a rebuild much more involved. Not to mention the valves might be fighting something lower, but at least they wouldn't all toast out too. The truck runs, that stuff isn't ruined, yet.
I wouldn't run the motor again. I would take the fan shroud and the fan off and move the engine with a ratchet or a breaker bar. Try to get the harmonic balancer to line up with the 0 degree, TDC mark. Try using a mechanics stethoscope to find where the sounds are coming from. Metal grating like that should be reproducible. Something is grinding and I bet you can even feel the vibration in your fingers when it starts.
If it's down in the lower unit, there will have to be decisions made, but rebuilding from the top end up is a breeze, really.
The whacking noise at the end sounds like a chain rattling against an aluminum housing. The timing sounds off. Both ends work, but it sounds like they are fighting each other. The cams might be toast, but you never know. Those are stout pieces of metal unless one of the cam brackets breaks because it is getting crushed by the lower end.
I think I would tear it down to the head cover removal as outlined in the FSM and see what that looks like. What do you have to lose? You have to take all that stuff off to rebuild anyway or sell the parts, so you might as well get cracking.
