SCORE! (finally)
If I stumbled on that deal, I would be researching hard into the LS swap threads. Looks fantastic.
As sweet as that would be, I'm going to have to keep it simple on this one. I'm also a bit intimidated about getting everything to work with an apples to oranges type swap. I can handle dropping the same engine in there, but spending months trying to chase down weird gremlins is more than I can take on right now.
1HD-FT + 5 speed... :D
Is that 1hd a straight forward swap?
Having just completed converting my 80 to a 1HD-FT and 5 speed, my advice is start saving your $ if you want to go this route.
Parts alone will run you a minimum of $15k, and that is going stock, no mods, doing most of the work yourself, and you have to find a motor. Once down that rabbit hole, the bills stack up quickly.
Fixing the 1FZ-FE is the easy route, followed by an LS, lastly diesel.
The diesel motor and trans are amazing, just very spendy.
Welp. I guess that answers that question. For that much, I would be tempted to import some JDM thing.
I have a good used engine for sale.195,000 miles.Pulled it to do a cummins swap.I'd take $600 for it.Its complete minus the ac compressor and a few sensors
I might just take you up on that. I'll let you know as soon as I confirm whether this one is toast. What part of the country are you in?
I did a 1FZ-FE trans and engine swap. I found someone local with a 1FZ-FE with 72k. it is in and running now. Fairly simple and I had the old engine to take parts form. Like sensors and other small but expensive parts.
Funny, I was literally just reading your thread. Nice job!
It seems like this is going to be a case of it being something easier rather than harder to fix. These trucks have like 2 gallons of oil in them. Unless it looks like Prince William Sound after the Valdez was done with it underneath, I just can't fathom burning that much oil without the driver having any clue that it was doing so.
At any rate, for what you have into it thus far, even if you have to completely rebuild the motor top and bottom, you will still be in for market value for such a truck. I'm more than a hair jealous. :clap:
Wouldn't that be great. Not getting my hopes up but it's entirely possible.
So a quick report: The battery was totally dead. I dropped it at autozone on the way to work this morning and picked it up on the way home. I checked the dipstick and it read full, and the oil looked new. I kind of figured that the first thing they would have done would be to put oil in it so that kind of makes sense. I connected the battery and it was still dead. I guess that will be item #1 on the shopping list. I pulled my battery out of my 91, and connected it and bam, we have lights! (By the way, the blinkers all came on, blinking even though they weren't turned on, with left and right blinking at different frequencies and all the dash lights blinking too. Is this normal? I thought it was odd).
Anyway, moment of truth, I turned the key annnnnddddd... nothing. Not even a click. I would think if the engine was in fact seized that I would at least hear the starter engage, but nothing. Dead silent. What do y'all think?
Next step is to check the oil filter for metal. I dont think it was changed, because it has mud splattered on it which I doubt would have happened with it sitting in the garage. Now if only I could get the bugger off :bang:
Also going to pull the spark plugs and see if I can track down a big ass socket to turn the crank.
Man you had me excited, but I checked the fusible links with the multimeter and they're all zero ohms.
I had to put the battery back in the other truck, but I'm picking one up tomorrow to continue. Got the oil filter off and tried getting it open with the can opener but no luck. Going to have to pick up some tin snips too.
The lack of any sort of nasty noises has me encouraged though!
The blinking lights seem fishy. Is the wiring harness melted behind the EGR valve? I wonder if the harness melted and shorted the ECU. That may account for the weird electrical symptoms and the dead engine.
Do you have the remote with the alarm? Maybe an aftermarket alarm and it shorted out.
It's weird. It only happens for about 20 seconds and then goes back to normal. It only seems to happen when the battery is disconnected and reconnected. The battery I was using is also on its last legs. Getting a new battery after work and also checking for shavings in the filter/oil.
It's got a fairly normal looking key FOB. I'll have to check and see if it has an alarm. Hadn't even thought about it to be honest.
The more I think about this, the more I am questioning the PO's conclusion that the engine seized. The oil plug had not been touched, and still had mud caked on it. I feel like if someone had done a proper diagnosis they would have at least drained and inspected the oil, and if they couldn't be bothered to drain the oil pan, I'll bet cold hard cash no-one put a wrench on the crank to see if it would turn. At this point, the only thing we know for sure is that it died at a stop light and the oil was very low when it happened. The two may or may not be related, and the lack of any sort of clack from the starter hitting a seized flywheel has me leaning slightly towards "other" as opposed to internal engine damage. This family had a big ol' house in the burbs with a really nice Porsche 911 Carrera in the driveway and a few other really nice cars. I kind of think maybe they just didn't want to deal with their 20 year old cruiser anymore, and didn't bother to spend the money getting it checked out, but rather decided to write it off. Sorry for the brain dump. I'll keep you guys posted!
