School me on Throttle Position Sensor (1993 HDJ81)
Calgary
Website
www.rmlca.ab.ca
So I'm getting an error code 41 from my O/D light, and I don't have torque converter lockup since my injection pump rebuild.
The Error Code 41 is: Throttle Position Sensor. I did the resistance test on it and it ohms out ok. The wiring harness seems ok, and I've already (foolishly) replaced the ECT and the O/D solenoid before I actually read the trouble code.
Questions:
  • After the resistance test, does that mean it works 100%?
  • Is it fixed or adjustable?
  • Does it have any connection to the Injection Pump?
I've looked up in the Body and Chassis Manual, the 1HD-T manual, and the A442 manual; and there is no reference to the Throttle Position sensor that I can find.
Should I just replace this part on spec?
I have found Va and Vc pins are swapped around on my TPS and on a mates also???
Regardless, have you done the voltage test? 5V power supply required.
It is adjustable by loosening the 2 mounting screws and rotating the sensor on the injection pump.
It is adjusted to provide a voltage reading at full throttle, not no throttle. I can't remember 100%, I think it is 0.8V at full throttle. About 3.4V at no throttle.
I would recommend marking the current mounting position and removing the sensor off of the pump just to make sure it is sitting on the throttle position tab things properly. This is easy to get wrong. This is the connection to the injector pump.
The TPS is for the electronic transmission only, doesn't play into the engine stuff at all.
How did you confirm you're not getting TC lockup? I remember there was some confusion on how it all worked in another thread. Should lock up in 3rd and 4th (OD) at about 85km/h in my experience. Easy to test in 3rd (OD off) as it feels like another gear shift and you can watch the tach.
Which manuals are you looking at? If they are earlier versions they won't have any of the electronically controlled transmission stuff as the early A442F's were fully hydraulic.
Since the IP rebuild the O/D light was flashing, I went thru the diagnostic procedures and it gives me an 41 code.
It's definitely not giving me that last "shift", RPMs are about 150-200 higher at Hwy speed than before the rebuild.
I have the A442f electronic transmission, the FSM's I'm referring to pertain to my truck year and transmission.
I'll post a copy of the manual cover when I get a chance.
Old thread but I see it was never answered. I had the exact same problem after my injection pump was rebuilt and installed. Simple fix the guys who rebuilt the pump did not install the tps properly so it was not moving at all giving that code. Two tiny screws later and the code is gone and the truck is shifting correctly now. It was in limp mode so the trans was shift super early.
Since this got bumped, does anyone know how to properly adjust the TPS? I feel like mine is out of whack as I'm not able to get the truck to hold gears and shift anywhere near redline.
Can anyone give any insight as to correct adjustment of the tps? I'm in a hotel right now over a thousand miles from home with my wife and kids because my 93 1hdt with a442f is shifting all over the place. Replaced all solenoids about 7 months ago
I ran over some road debris recently and have gotten the 41 code that won't go away, even after replacing the TPS with a brand new sensor. Does anybody have a wiring diagram so that I can trace around to see if I have a severed wire somewhere? I can't think of any other fix besides maybe some adjustment between the TPS and injector pump? I'm stumped.
Did you end of fixing this? I had my Speed sensor short out causing me to lose my gauges. I drove around about 1 week without the speed sensor plugged in and my O/D light was flashing but i was still able to get into O/D lockup.
Once I got the new speed sensor and plugged everything back in now I get no lockup in O/D.
Im wondering if i fried my TPS or something in the circuit.
When the TPS is fitted you have to drop it in in the correct position to get the operating lever on the right side of the TPS. Then turn the TPS back to line it up with the mounting screws. Then turn TPS never sits at the zero position. If it is not in the correct position you will not get OD. The OD light flashes for many different transmission faults. You have to use the paper clip in the OBD connector to read the code.
Which terminals need to be shorted out on the OBD? What FSM tells me the fault codes?
Im not quite positive that my TPS is the current issue to me having no O/D lockup anymore. I adjusted the voltage output on it today and the lowest I could get was 1.05v @ full throttle. It changed my shift points for sure but did not affect O/D lockup
I have a post started.
Toyota HDJ80 - 1HDT TPS Adjustment for Shifting Flare​
i hope this will help the future people.
