ScanGauge II w 01 or 02 LC and trans temp
Hottest I saw was on hill climbs on Colorado highways, and was around 165.
Thanks for posting that code! I bought a scan gauge on sale on BF and trans temp was my primary reason. Pic of my setup.
Anybody got this to work on an 05? I tried this and several codez on scangauge's site but no luck
Nevermind, found them here, thanks @abuck99
This code worked on my 05
Scangauge:
TXD: 686AF121B4
RXF: 046105B40000
RXD: 2808
MTH: 00090005FFD8
Heres a thread to research other options: I think the codes that work on the newer 100's are backwards compatible
Transmission temperature on a late model 100 series
And then a more in-depth thread:
Torque app plus bluetooth adapter in my 100
Can confirm this works on an '02 LX!
Anyone know if there’s a different code for 2006? I have TFT but no numerical reading…
Edit: had to send it out for a software update. Works great now.
I have a 2002 LC100. I tried the various codes posted on ih8mud and had high temp readings that fluctuated. I was able to locate these codes for the ScanGuage II on the scangauge au website Temp reads in celsius.
Incase the pic doesn't load:
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00010001FFD8
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00010001FFD8
Thanks, I ended up having to send my scangauge out to get a software update and now it works.
I have mine programmed for the 03 LX that I moved to the’00 LC and it’s going back and forth between 2 numbers. I’ve never seen this before. Anyone know what’s going on?
