I assumed that your motor was a brushed motor. Brushless are primarily for faster machines. Being a crawler, it's probably brushed. Do you know the turn count? Most folks use 45 or higher for true competition crawlers. Our crawlers are set up for crawling and bashing so I like to use lower turn brushed motors for more wheel speed. Our AX10 has a 27t and I run a Traxxas Titan 21t 550 in the Wraith and SCX10. We do run a brushless VXL motor in our EXO-terra because it sees mostly track duty. It'll run 50mph easy. Agreed on the LIPO cutoff. That's most likely your problem. I would not try to do anything else with those batteries until you charge them up. You can pull the voltage down on a LIPO to the point that it won't charge anymore. Always disconnect the batteries when storing the crawler. All it takes is a miniscule short somewhere to pull the battery down to the point of no return.
Now to learn how this fancy radio works
