There is nothing with being a bike geek. I have a steel 29er hard tail that I love. Steel is where it is at.
That is the whole driving force here.Won't it be nice to not hear the rust-mites nibbling away?
Yeah, if I don't get it back on the road in time it's all your fault Jon.Kevin,
Sorry the gate lid you built for me slowed you down mid-build.![]()
That's great Jon, If I can encourage people to keep what they have and work on keeping it in good shape that is a good thing....... and now I want to keep my 60 and rebuild it with my daughter as a father-daughter bonding project. Which should be fun, since she is not even 2 yet... Today I taught her the word ratchet as she helped me install a steering stabilizer.
I need to hang out in the 60 forum more. Great work man!
Great work, I really like the way you trimmed the bottom of the rear quarters and then used the glue.
I've been following along and I like the way you jumped from a sorta sanded body to painted in 4-5 pics. I should do that, as i did my 60 last Dec, with 2-3 pics and forget the 400+ hrs in between. It is lots of work, and the results are worth every minute! I'm saving $ for your rear deck. It will finish the back up nicely!
Oh sure, now that Im finished with the sanding.I am sure you will have this thing built before I get a free day but I am open off and on after the 20th if you need a hand!
Clint
Kevin,
You boxed in your rear frame sections; will that not reduce the amount frame flex that is inherent in cruiser articulation? Or would that not affect it?[ /QUOTE]
The short answer to that is; I have no idea.
I stared at it for awhile and I don't think so.
I basically took the part that was already in there, remade it and flipped it around. At the same time I removed the rear tire brace and the bumper tie-in brace, the bumper puts that support back in but still allows the twist (I think...)
It should be fine.
So, I don't have time to caption these but I will post a bunch of photos for now, some exciting stuff....
EDIT: Some captions added for info.
Disassembled and cleaned all the HVAC inside and out. (so nice having hot running water in the garage)
No idea if it will help anything but I had all these scraps of foam I have saved over the years so I re-did all the seals and insulated the ducts.
I know that with the AC blasting they get a lot of condensation on them so the thought is that this will help, and might make things quieter under the dash.
The pile of crusty old foam that used to be in there:
