rust bubble repair
I wanted to try to stabilize the rot since I don't know how long it's going to be until I can do the 3/4 tube.
Here's where I'm at now, and I'm almost at all good metal.
1971216
Here's from underneath, where all the real damage was. The hole in the side is mostly to give me access.
1971217
That metal is paper thin.
Luckily, there's decent metal all around. A couple of patch panels on the bottom and the front, and some welding of pin holes, a lot of POR15 and I'll call it good for now.
Made some progress. My welding isn't perfect, but it's good enough.
But, in the end, it was an ugly repair. The damage to the bottom of the rocker panel was pretty bad and not worth the effort to fix it. So, I did what I'm sure will shock some here. I coated the inside with POR15, filled the void with closed cell foam, and then used JB Weld and some little metal plates to seal the bottom. It's ugly, but it will get me through the next couple of years.
1976569
Not incur the wrath of all the diamond plater haters on this site, but I'm not diving into this rabbit hole until I'm ready to take the tub off and completely have it done. My only choice is to stare at rust, or grind it down, seal it, and put the diamond plate over it. :rofl: For now...
You meant to say, slather it with axle grease, and then cover it with diamond plate. If you 'seal' rusty metal to diamond plate with caulk (or any drying/hard/sealing material), you will make it worse by trapping water.
Rusty metal, entombed in axle grease, will not rust, even if covered with (gasp!) diamond plate.
My plan was to paint the backside of the diamond plate with rattle can bed liner (so I don't get yelled at for aluminum on steel issues). then wire wheel/grind the surface stuff and then do a liberal coating of Corroseal rust converter primer. Might have to consider the axle grease on top of that as a good measure. I did read somewhere on MUD that a small bead of caulk along the top and down the sides helps to keep water out while allowing drainage through the bottom?
Trust me when I say that I WILL pull the tub, or find a donor, and completely go through it someday... but right now I need to think "GO" before "SHOW" and budget the other things I want... like power steering... and a rear aux tank as the only tank... and a tire carrier... and front cage... a winch... not to mention first and foremost a whole lot of damn gaskets and seals! LOL!
So, I'm down to the color coat and I learned a few things. I went down to my local auto paint store wanting to get a spray can for Freeborn Red. But, they were out of spray cans. So, they sold me this thing, which is really cool and works great. But still $90 for a quart of Freeborn Red. But, the color was waaayyyy off from what's on my rig, which I had assumed was Freeborn Red. So, I had this random can of red Rustoleum that is actually a lot closer.
1985331
However, as soon as I put it on, I realized I had not done the bondo and primer correctly. There was all kinds of texture showing through. Clearly I should have spent a lot more time with finer grit sandpaper getting it smooth. Interestingly, almost none of this was visible with the primer - or looked barely visible. But, with the color coat, it's screaming - YOU'RE AN IDIOT!
1985332
1985333
So, screw it for now. As my friend says to me 'stop worrying and just drive it'. I'm going to take off the masking and drive it until I'm inspired to do some thing better.
We have everyone experienced the same thing the first time. You just learn by doing. But this is your temporary fix, so just drive.
