Runs Hot - help please
Long Island
1997 40th continues to run hot when towing small trailer or driving on beach or anytime it's working hard. I am at my wits end. "Normal" road driving is never an issue but if stuck in traffic w/ A/C on the A/C will occasionally cut-out. Last year I pulled motor and did did all of the following:
Head Gasket, head re-done, all new hoses (including all the little hoses and mixing valve on firewall), thermostat, water pump, hard lines to rear heater, radiator, PHH, fan clutch, every single gasket and seal, sent out the injectors, new EGR and PCV and all new vacuum lines, and basically anything and everything that was rubber was replaced. All parts (except rad.) were from Toyota. I am stumped and in need of help. 265k miles and runs great, except for the temp. issue when under heavy load. Is it possible tranny is the heat source ? Removed stupid little "skid-plate" under rad. support - that do anything ?
Essentially the entire cooling system is new and filled with Toyota Red antifreeze - but still have to be very careful offroad to not run her too hot. I have been through a zillion threads, can't find a solution. Anyone have any ideas ???? Getting desperate. Thx.
Viscous replace oil.
Is radiator cowl still in place?
Is your kick down cable installed correctly? Often replaced in the cruise control position.
Thermostat and Oring replaced?
I am going with ZA80 on this one. Even new from Toyota the new blue hubs seem to be awfully anemic.
Double check the system is burped well. Get the front much higher than you think it needs, make sure the rear heater is on, front heater is on and let it come up to temp. Hopefully you'll see some gurgling and burping.
Good luck
Thermostat and o-ring genuine toyota - 6 months ago.
Kick-down cable placement ? No clue but everything works correctly so I assume so, will check. How would that influence temp ?
A quick note. It seems like folks always want a silver bullet when it comes to a problem, but unfortunately a cooling system is just that a "system", so there are many parts that work together within that system and if some or all of them are not working properly then that system will fail. So the answer is regular maintenance or PM on the entire system.
..........It seems like folks always want a silver bullet when it comes to a problem, but unfortunately a cooling system is just that a "system"........
Agreed- problem is that I have replaced everything w/ new. It's so frustrating.
