*EDIT: Urgency is over just getting it taken care of now. Will report back on results. *
I'm in the middle of nowhere Illinois/Iowa and just watched the oil pressure needle drop. I stopped, checked the oil and it was low on the stick, but it was on the stick. Got a rude to the gas station and bought 5w-30. I added 2 qts and if came up to full. At idle the needle is on the bottom line. Engine runs and sounds fine. Pressure isn't holding while driving. What's going on? What should I be checking?
job to remove the oil sender from the block to screw in a test gauge and read your actual oil pressure. Many autozones have this gauge for rent.
