Code reader says throttle position sensor stuck and a whole bunch of other things. Will start, rev up and then immediately shuts down. Code reader also said voltage is low. Any ideas? Thanks,
Low voltage causes all kinds of crazy codes, That being said if it has enough to crank it it's probably not the battery. I'd suggest removing Neg. cable for 10 min and see if that resets anything. This will cause a 1 time start and stop but subsequent starts will be normal.Voltage is low? Might need a battery.
