RTH! Bishop CA
Dante's Inferno, CA
We're here in bishop and lost the panhard bolt off one of our trucks wheeling at Funnel Lake. Anyone in the area have a spare? thanks in advance.
Bump. Wish I could help, but I'm way too far away...
I think it's a m17x1.25 and will be hard to find local probably but there are a few napas up there that may have something close like max suggested. There are a few other places on the truck that use the same size I believe (control arms I think). Depending on if you're just going to be on the road or try to keep wheeling will be a deciding factor. Best of luck
No luck at the local Toyota dealership although they let me rummage through their piles of old bolts. For a quick trail fix I used a socket to keep the panhard from coming loose and then a ratchet strap to keep the socket from popping out. Wasn't my truck but I was riding with him. Wasn't the end of the world but a tad frustrating. Enough to ruin our only solid day up here with @Qball @jtwopark @ewillis and @dr gill
Pics incoming.
You could probably drive (at low speed) very far without the panhard bar hooked up.
Dyno
250 miles on trail repair v2.0 and holding up perfectly:
* socket, check.
* bailing wire, check.
* duct tape, check.
* safe drive home, check check.
The NAPA in Bishop is very helpful the two times I've needed something weird, and the shop in the back usually has a 40 or two in the lot...
Well the guy there, Art, was trying to be helpful but didn't really understand what we needed. He tried though.
Wouldn't one of the bolts from the retriever hooks in back or front fit through there and be tight enough to hold? Or am I thinking wrong?
No, this is a huge bolt. Same size or larger than the control arm bolts.
I foresee a flood of orders for spares - Toyota will have them on backorder any moment :lol:
grrr...frustrating indeed! but i got home safely...going to see how long the trail fix lasts...lol
