Forgive me if this is a dumb question, but where would I find the connection point to disconnect the module?
is not the same.I don't see that the fault is apparently in the combo meter (at least I wouldn't look there first):
The way I read the diagrams, "1D" grounds only the fuel and voltmeter. The speedo and tach are grounded through the combo meter. I could be wrong, I haven't looked that closely at it. Yes, you're correct about the damping; IIRC they have springs on them. I have two out on my bench right now. I need to swap the trip-o-meter in mine for one that works. I'll look when I pop the meter open.@Malleus Isn't that the ground point "ID" down there in the lower right corner? If I follow it back, it is the ground for the voltmeter, speedo, fuel gauge, and tach. Some of those needles are damped, I imagine, and therefore wouldn't jump. By the way, THANKS for posting the diagrams, it helps a lot! Especially where an LX450is not the same.
And @Chachi254 , to disconnect your trailer module, look behind the right rear side panel (subwoofer). There should be a module there that plugs in-line with your taillight harness. Disconnect the module from both directions and return the factory harness to normal by plugging the two OEM connectors together. You don't need this unless you tow, and if you do, go buy a new one and reinstall it. Old ones just shouldn't be trusted. This could very well be a part of your troubles.
Back to your original post: When you say "turned on the headlights", may I assume you went from a fully off state, not park lights? It would be interesting to see what happens with park lights only. When you "turn on the lights", the dash cluster gets fed lamp power too. Play with the dash illumination knob thingy.
My fear is that you'll wiggle a wire and things will go back to normal. For a while. Thenagain some day.
This may or may not be a related symptom, but I’ve been having some weird electrical issues as of late where my cruise control doesn’t work when my headlights are on, pressing the brake turns on my dash lights
Check to see whether or not the antenna switch works when your radio lights go off. I am assuming here that you have the factory stereo.
Also, you should have a light in the ashtray, when your radio lights are on.
I meant the ashtray light, not the cigarette lighter, that's on a different circuit.
That sounds like a body ground fault, on the kickpanels (1D & 1E):
It may not be at the ground screw, but in a connector somewhere. You'll have to trace the circuits until you find it.
