rough ride
I purchased a '78 FJ40 with 70K original miles on it a year ago and have been in the process of restoring it. I have a friend who owns a body shop who took it down to the frame and fixed all the rust spots and repainted it from top to bottom.
I put in a new carb, headers, new interior, a/c, headliner and weatherstripping. Now that it's all down I want to improve the ride. It has the original suspension and is rough as a log wagon. Since virtually all of my use will be on the road, or worse case on gravel roads, I'd like something smoother. I'm thinking about a 2 - 2.5 lift kit and would like to also cure the "lean" while I'm at it. Any and all suggestions will be appreciated.
Very nice cruiser by the way.:doh: If you want to change your suspension to something smoother, but don't want to over do it for major offroading, then 2.5 is great! Good luck:cool:
Smooth ride is a pretty subjective term. If this is the first short wheel base solid axle vehicle you have driven, you may have an unreasonable expectation of what kind of ride is possible.
My experience is that the stock springs are about as good as it gets for smooth ride.
They will never ride like a stinkin' Lincoln.
well fella, first off, great lookin ride!!! :D
now for the 'lean'. theres a few threads on this forum about how to fix the lean in 40's. i'm of the opinion to go for the leveler blocks. just go up to the search part in the above bar and search for 'cruiser lean'. it'll give you heapsof info and links. :flipoff2:
in my experiences i've found lwb's are normally a smoother ride than swb's. onroad anyways.. as for smooth ride, start messin with spring rates and ya mess with cornering stabilities... i'm with weeny on this bit tho.. std springs with possible adjustable 9000's... :D
ahyhow, great rig.. keep us posted! good work!!!! :bounce: :cheers: :bounce2:
Cool cruisers has a great suspension system that also fixed the elan. HFS. I have heard alot of good things about them
Longer shock travel
adjustable shocks
revolving shackles
i think all of those will very much improve the ride
but above all it will always be a bouncy cruiser! They all are!
Those seat covers are sweet. Stock is about the best your gonna get for ride quality. Determining your correct shock is important, Bilsteins are also quality shocks to consider.
x20 on keeping the stock springs. NOTHING aftermarket will be as soft.
Idea number 2: LET SOME AIR OUT OF YOUR TIRES. From your photo, you can see that your tire patch is not getting full contact. If you read the load specs on those tires, they're prolly rated for a vehicle that weighs 2000 lbs more than your cruiser. Without that extra weight, the plys will not flex according to manufacturer's specs at standard tire pressure.
Or you could spend 4k and add the weight in with a brushguard, winch, rollcage, auxiliary tank and custom rear bumper/tire carrier,cooler rack, rock sliders and a roofrack. ;)
I've got enough extra weight in my 40 to make even the stiffest of springs, the old 3 leaf Ranchos, flex pretty good.:eek:
Best
Mark A.
Best
Mark A.
That is one sweet ride. I'd like to see more photos. I have the OME 2.5" lift with their shocks. It will give you a ride that is not near as harsh as the factory setup. Putting new springs on will not take the lean out in and of itself. I've changed the springs twice and they changed the ride but not the lean. I'm not sure if you know just how much the source of it has been discussed and solutions offered. CCOT offers a plate that you install on the rear passenger spring pack that lowers the spring pack to counter the lean. It seems to work as long as you are willing to give up a fraction of an inch of ground clearance.
