These might be coming to my garage pretty soon.
I currently have Poly Pro chromoly semi-float axles. I need to pull them and check for wear. I need to install new lug studs anyways. I broke one stud during the ACT 2010 and its time for them to be replaced. But the FF should be fun. Does anyone know where to get spare FF rear axles? Oh, and can I use my current third and install it with the FF axles or do I need to use the third the axles came with? I would assume I could use the third I have now. It has an Aussie locker in it and it is 4.11. Just wanted to make sure.
Chad
Sweet!! Don't you already have an H55 though?
As for the FF, good luck finding spare stock axle shafts. They are even more difficult to find than the FF housings themselves. Poly Pro makes 60 FF axle shafts that are really good. I'm running a pair on my DD right now. Unlike the SF shafts they don't need to support any weight, just transfer torque, and therefore the poly material is better suited to a FF application.
You will be able to swap your SF third in without issue.
Chad
