Roll cage design question
Pendleton Oregon
Website
www.oregongrain.com
What are the pros and cons of having a bar in your roll cage that fits like this between the B and C pillars
Vs this?
Just asking questions because I can! :cool:
Top pic is structuraly (sp) stronger.............
You got "bitter bear face" and can't smile for the camera?;)
I would take those if it meant you were safer....;)
Ok, What if you installed seats and ran tube from top right or left to mid b or c pillar. Not a steep angle but would serve both strenght and retaining your jump seats.....
It would be like your bottom pic, one end would stay put and the other in the upper corner.
Triangulation is critical in any structual design. The second picture essentially does nothing but add weight to your roll cage. The second design may even weaken the cage in some instances. Nodes and triangulation are key.
If you rotate the bar in the top picture so it comes out straight (parallel to the side) from the b pillar then bends back into the c pillar would your seats fit?
That's how I had mine installed. It kind of shows up in this pic.
<image deleted>
I wasen't to worried because I never plan to have a back seat, but it makes more room for gear and the dog.
Soryy about that I'll re-post the pic after I edit the lic# out.
Not as good a pic, but you can see where it ties into the c pillar.
I also added a dash spreader. Eventually I will add a set of cross braces in the b pillar behind the front seats. This will stiffen the whole cage and help stop it from folding over.
<image deleted>
Do you have a pic of how the angled tube between the B and C pillars was attached? Does it attach to the base plate? Or to the B and C pillar only?
Thanks for the pics Bull, looking good.:)
Was wondering if when you were thinking about that front bar if you ever considered mounting it to either end of your dash, ie, you would probably have to relocate your headlight switch. I have seen this done but almost everyone goes for the foot-well floor mounted option like yours. Is the floor mount method safer or stronger in any way?
Bull,
Sorry, I don't have a better picture. I'll try to get one for you later.
Anyway the bar is between the b and c pillars, the long straight section is in the almost the same plane as the a and b pillars and the short bent section connects to the c pillar.
Lacking a picture I'll try to sketch something up later to post.
