Rocky Road Sliders
Thinking of installing a pair of these on my truck. Curious if anyone has experience with them or if there is a superior product at the same price point. Also looking at Metal Tech. Opinions?
I know someone that has the rocky - road sliders and had a lot of issue with the install that they had to have some fabrication work done on them just to get to fit correctly. From what I here - spend a few extra bucks and get some from a another manufacture - Heard good things about White knuckle that are a very good slider for the money.
read through my post in the thread that was linked a couple post back. My experience with rocky road sliders was horrible. highly encourage you to find a different brand. customer service is horrible and if you have any issues they couldn't care less. I ordered the white knuckle sliders for my 100 series. Far superior product with significantly better customer service.
I've had them for a year. Not worth getting. This is what I wrote to them
"The Bad
They are too short, they don't provide full coverage...which is a bummer.
My pinch weld is bent anyplace there are support bars. The support bars need to be thicker and/or further away from the pinch weld.
There is too little support from the support bars, If i try and hilift I get several inches of deflection, these bars need to be thicker.
The material used for the backing plates is too mild a steel and bends easily.
The bolts are rusting badly already
I did not drill into the pinch weld to attach the support piece to it - a body on frame truck needs a separation between body and frame i don't think its wise to tie them together, this method should be ditched all together.
The good
The powder coating and strength of the cat guard and sliders has been great. Hit them alot and they are looking nice still.
I think you should consider the 0 degree "step bar" configuration as a production model, the step feature is great and it also acts as a door saver since it sticks out far enough that lower cars hit their doors into it, instead of into my doors.
If you do consider it, grip tape that sucker, its SLICK. (I grip taped mine)
Again. Take it as constructive feedback and not as criticism. I think your slider design is great but you should rethink them in the following ways:
1. they need to be longer, at least 4-6 inches longer.
2. The supports need to be larger diameter and further away from the body
3. The steel used for the mounting plate needs to be stronger steel
4. Use stainless hardware for the bolts.
5. Ditch the pinchweld mounting idea completely"
Talked with Kurt at cruiser outfitters about them and his take was "we take off a lot of these", as well as "they know they are bad, but they've been making them so long they have no intention of fixing it."
Not worth the money, that having been said, they are working okay for me so far. They have bend my pinch weld slightly in a few spots but they also have saved my cats and sills more than they haven't.
I have them. They are cheap because they are probably the lowest quality slider available. The fit isn't very good and required significant cutting and re welding to attach properly. I regret not spending another $200 and getting something I am confident with. Worse yet is the company wouldn't stand behind their product and were argumentative with me rather than apologetic. It was also very evident that they do not know there own products at all. My phone conversations about fitment issues were pointless because they had no concept of how they were designed to fit. Mine are still on my truck and are providing at least some level of protection. If you are in Phoenix and want to save some coin you can buy mine.
20150125_120056.webp 20150125_144737.webp 20150125_144819.webp I bought the Outpost Off Road sliders from Metal Tech. Price was better than others I found. Quality looks good. I haven't bashed it on rocks yet, but used it as a jacking point when installing my lift kit. Very little deflection. The skid plate is super sturdy looking. I like the looks of the dimple plates. I'm still uncertain if I think it sticks out further than it needs to on a deflared truck. Unless I find a trail 2" narrower than my sliders, I think I'll consider them perfect.
I try not to be a jerk on forums but seriously just a quick search would have told you all this already. They're cheap for a reason.
I have the white knuckle offroad ones. They are great and reasonably priced.
I have Slee's they fit great and solid. Maybe a few more bucks but it's worth knowing they won't let you down.
Where's the excitement in that?:rolleyes:
View attachment 1082376 View attachment 1082378 View attachment 1082379 I bought the Outpost Off Road sliders from Metal Tech. Price was better than others I found. Quality looks good. I haven't bashed it on rocks yet, but used it as a jacking point when installing my lift kit. Very little deflection. The skid plate is super sturdy looking. I like the looks of the dimple plates. I'm still uncertain if I think it sticks out further than it needs to on a deflared truck. Unless I find a trail 2" narrower than my sliders, I think I'll consider them perfect.
I also bought these from metal tech this winter. Just installed them a couple months ago and didn't properly "test" them until last weekend. I bashed them off of rocks all day long and they held up great. There was a little deflection and they touched the pinch weld a little, but with dragging a heavy 80 series on them I am not surprised. I have aftermarket cats on my rig and plan on cutting down the cat protector and re welding it because it sticks down way too low m for my cats. Here is a pic of them after the giving them a good test.
Note that the dents in the door were there before the sliders were installed.
