Coming from a mini truck genre, there was the old rule of 4.88's being 1 full tooth stronger than 5.29s. The theory, made possible by seeing it firsthand, was that 5.29s had two constant teeth in contact with about half the third tooth coming g and going. The 4.88s had a constant 3 teeth in mesh and a 4th tooth coming and going. Keep in mind this is from a mini truck heritage, so the front axle should be similar from what I'm understanding. 1) Does this rule apply to our 80 axles, I have a hunch it's slightly less with the front being reverse cut? And the rear should be the same, just a larger portion of pie if I'm not mistaken. 2) With 37's, naturally I want more meat vs. The exact gearing needed to make my rig ideal on the freeway. With breaking 5.29s numerous times in the mini truck, and learning 488s are 1/3 stronger, I changed to those and never broke again. Does this seem to follow the same path in the 80? I went rcv inner in the front and now the r&p will be the weak link which I want to avoid by doing it once, with quality aftermarket parts (yukon) and not worry about it. Anyone have the info I'm looking for with this matter? I'd rather do me research now while I'm ahead of it, than be on my second install full of regret
Phil
Phil
