replacing stereo
Scion Head Unit Install
Nakman and I put in 2006 Scion Head Units today.
We figured out we had to pull all the connectors off the dash insert to work on it. Dremel tool and file and knife did it right.
The Scion unit is much wider than the stock HU. We measured 7 7/8". We mostly just trimmed the center insert and a little off the Scion faceplate. There was a trim plug/insert on one side of the opening we completely removed. We also had to grind a little off the 80 mounting brackets to fit to the Scion unit. The last pic shows the amp plugs behind the PS speaker removed. We took the glove box out to do this. The one thing we forgot and had to go back in to do was to use the second gray plug from the stock harness that was originally taped off. It makes the rear speakers work. I may try and re-fit my wood trim around the radio, but I have to trim it for the power and eject buttons. Not too bad a job, and it was real nice to have help.
Thanks Tim!! :D
KLP -
I just replaced my head unit with an Alpine unit with XM and an iPod adapter. Easy as cake. I went with a single DIN deck but, that gave me a pocket to use below the Alpine. The Alpine's have an awesome iPod interface, it is quick and everything is controllable from the deck. The direct XM interface is great as well, no loss of sound quality (opposed to FM modulated). The whole project took about 2 hours. The main thing you have to remember is not to hook up the power antenna wire. Everything else is simple and straightforward. Just remember that using the standard Toyota wiring harness you only use 2 of the 3 plugs, at least on mine.
I went with a full alpine system except a pioneer subwoofer. The head unit is single, so I too have the pocket below which is quite useful.
When replacing the stock unit in mine with a single din unit, a plug in wiring harness wasn't available for a few weeks so decide to just cut the wires and solder the new system in. If doing this be sure to check the selected earth wire with the lights on as well as off. I found this out the hard way and was wondering why I kept blowing the park light fuse.
Does anyone know if the "gray plug" that is for use w/out the factory amp, is available in the LX450? If so, does anyone have a pic or description of where to access it, as I can't seem to find it? I hooked up a JVC headunit and have an awful hiss using the factory amp, I've tried messing with the ground to no avail. I'd rather just try to have the headunit drive the speakers.
If its any help, i just replaced my stock Head unit with a new Sony head unit and just went to Circuit City and told them what i had and they handed me a couple of wire sets ( all plug and play) and i was on my way!
I put the stuff together and BAM i was in business! One thing, on 1997-1996 mabey 95-94 there was a red wire with a black stripe that i had to cut to disable the auto antenna thing (really didn't do anything physically to the antenna but it stopped the radio from heating up).
If you need more info let me know i can walk you through it.
i currently have a sony HU in my '96 and wanted to go back to either a stock unit or a scion HU. has anyone done this? if so, would it be a simple matter of taking off the sony harness/adapter then plug in the scion to the stock harness? i haven't pulled the old unit to see what's been done back there, but just curious what i might be getting into. thanks.
If they did it right, then that's all it should be. There are two plugs available, one that feeds line level to the stock amps, and one that bypasses the amps and goes directly to the speakers. If the sony has the amps built into the head unit, then hopefully they just disconnected the amps and used the bypass.
Or... they coud have cut everthing and connected with electrical tape. Do you feel lucky?
I just replaced my radio for the second time. I got a JVC with built in HDradio receiver and iPod connectivity. Single DIN size, no dash trimming and I have a CB under it with a face mounted speaker. Use the bracket off the stock radio and bypass the cheap stock amps.
does anyone know where you can purchase the plug that the ipod fits into with the Scion radios?
I was hoping to avoid a dealer and pick one up off a bone yard vehicle or online.
I am trying to put it into my 4runner
ebay or maybe the classifieds. IIRC it is stupid spendy to buy new.
