replacing stereo
Is this a DIY? Any special tools? Does the who unit pullout or just CD player. Does anyone reccomend a particular brand?
its a double din unit so yes it will pull out as a whole, as for special tools you dont need any, but it is a good idea to get an FSM (factory service manual) it will tell you how to take it out. As for brand any will work, you will need a dash kit and a wire kit to splice into the factory system.
CircuitCity or Crutchfield are the best places to look for all the stuff you need.
As i recall they both sell the wiring harnesses(2) you need so no cutting is needed and both should sell the "pocket" to put under the new unit.
Alot seem to be pleased with alpine head units.
IIRC, if you buy from Crutchfield, they throw in the wiring harness and mounting kit for free. Granted, you'll pay shipping, but if it's less that 30-40 dollars (and it should be) you'll probably come out ahead.
I replaced mine with a Scion unit I got off ebay for $70.00
It's plug n play and the brackets from the old unit bolt right on.
You do have to do a bit of trimming of your dash plate and the
head unit face plate. Make sure you disconnect the factory amp
behind the glove box as the Scion has a built in amp. It's a factory
looking cheap solution that sounds great and you can add XM satellite
service too.
Check out these threads as well
https://forum.ih8mud.com/showthread.php?t=24014&highlight=dash+lights
https://forum.ih8mud.com/showthread.php?t=78477
I can take pics tonight and post them if you want.
Hey, I'll sign up to see some pix! I'm looking at both versions of the 2006 Scion HUs, and would be envious if you scored the high end jobbie for $70. Also, and more importantly, I need to know what trimming is needed to fit the Scion unit in the opening for our standard HU. If you could show that detail, it would be appreciated.
Thanks! :cheers:
Thanks! :cheers:
This is the one I got.
http://cgi.ebay.com/ebaymotors/Scio...ewItemQQcategoryZ43947QQitemZ8060765931QQrdZ1
This one is the latest version with the built in ipod connection
(although you can buy an inexpensive harness to attach an ipod to mine)
http://cgi.ebay.com/ebaymotors/Scio...ewItemQQcategoryZ43947QQitemZ8061169601QQrdZ1
I'll trade you pics of my stereo for pics of your rearview mirror install :D
Yes! Pics of the install. Ive been biudding on scion head units on ebay and nothing seems to sell for less than 100. Also - any other problems you encountered?? I have a 95 and I HATE the stereo...
thanks!!
Rich
Ummmm...pics on mirror tomorrow or over the weekend...PROMISE!
Thanks for the scoops on the stereos being auctionized. :beer:
thanks!!
Rich
I unfortunately didn't take pics throughout the install
(hanging out on this list, I should've known)
I'll take pics tonight of how it fits and just how stock it looks.
I cut the dash piece with a utility knife and the Scion faceplate
with a dremel tool. In hindsight, I would have bolted the unit
in to see how much dash plate and faceplate to cut. I did it by
measurements and probably could have cut less. It still looks good though.
In one of the threads I linked, it notes which connections go where
including the antenna.
The key to bidding on ebay is to hang out at the low priced ones
at the end of the auction (last 5 minutes) :D
You can check out my setup next friday https://forum.ih8mud.com/showthread.php?t=88675
or PM me if you want to hook up and take a look at it some other time.
Pioneer HU
Planet Audio mid and tweets
Crossfire subs
Planet Audio 700w 5ch amp
iPod running thru the AUX of the deck
:cheers:
Thanks Dave!!
I think if I had test fitted it, the Scion
face plate might not have needed trimming.
Looks great. Almost stock. Thats exactly what I want
Very nice look. Just to make sure I'm following, was this a direct plug-n-play deal from the wiring harness end? Also, do any of the Scion HUs offer in-dash Cd changers like many of the other OEM HUs?
I just picked up the Scion 6 disc in dash changer off ebay. I also found the USA Spec 2X aux input. I have been listening to Sirius through a FM modulator and I can't wait for digital quality sound! I will try to take pics of the install.
There is a Scion with a 6-disc in-dash changer?! Do you have the model, or a link to the ebay auction I can check out? Does it still play mp3?
Darn, maybe I should have kept looking (but I have a summer long trip coming in a week and really needed to get the stereo changed out).
You might have seen my response in this thread
https://forum.ih8mud.com/showthread.php?t=94000
but yes, it is plug and play. You will have to rummage
around inside the dash for one gray connector that's
not in use with the stock stereo, but plugs in to the
Scion unit. Make sure you disconnect the LC amp
located behind the glove box as any of the Scion
units have a built in amp.
Also, Scion does make a 6 disc changer that will fit right in
as well. I got the single disc because with mp3s at 192kps,
you can fit around 130 songs per disc.
Dave: Yep, saw it - thanks for the confirmation. I was just surprised that there was a 6-disc indash unit as I hadn't seen it anywhere on ebay. I did find it last night at a few online Toyota shops, but it was $500-650 whish is way more than I want to spend for my daughter's listening pleasure. I also thought the single disc with mp3 capacity was near the same as any non-mp3 6-disc changer. However, I suppose the 6-disc WITH mps would be really great. Again, though, too much cash for this project (I also nixed the Avic Z1 with the 30gb hd, navigation, rear camera, bluetooth, etc... that my daughter wanted for upwards of $3k just for the stereo and 'extra' without speakers or install).
Again, thanks for the help. I'll pull the blaupunkt unit that was installed by a local high-end stereo shop back in 2000 and hopefully all the original plugs will be there.
If you watch ebay for a few weeks,
you might find one at auction rather
than the $500 - 650 "Buy It Now" ones.
They are from 2004 I think, that's why
they'll be a bit harder to find. The new
2006 Version is like mine (mine is 2005)
but with the Ipod connection....that should please your daughter :D
