I've been hunting down holes and such in my rig over the last couple of weeks, and one of the ones that came to my attention after I ripped out the carpet and center console was the rubber boot under the transmission shifter. It's all part of the linkage that goes under the truck, and mine was ripped open. I'm sure 18-19 years of shifting didn't have anything to do with it!
For those of you who don't know what I'm talking about, it's PNC 33555:
After I pulled apart the console, it's pretty easy to get at. Remove the 4 screws that hold down the shift selection indicator, and then the other 4 screws that hold the transfer case boot on. Remove the transfer case upper boot (be careful with that - it's an expensive part to replace if you mess it up!), and then there are about 8 or so other 10mm screws to remove around the plate.
To make it easier to get out, get under the truck and pull the transmission shift linkage bolt (12mm). You might want to mark its position before pulling it, just in case. Let the rod hang loose.
Now comes the tricky part. Because of the way the boot is on the lever, you're probably going to want to turn the truck to "on" so you can shift around a bit. Note that since you've removed the transmission linkage, you won't need to worry about the truck moving, but you will need to leave the two plugs attached at the bottom of the plate.
Once you have the plate off, it'll look something like this:
(That's the bottom of the plate)
Mine had a nice hole in it:
After I got the boot off the plate (there are a bunch of small collars in there that you'll have to remove before you can separate the boot from the plate), the hole was easier to see:
It's about $35-$50 replacement item depending on who you buy it from.
