Thanks guys. And I paid a shop to do the #1 bushing and the ball joints. Money well spent.
Same. No matter what the cost, never again.[/Q
I have nightmares about the No1 bushing.
You can pull the control arm off and work on it on a bench. Otherwise, you can still buy the lower arm from Toyota with the bushing in it already....
Have you tried doing the No1 bushing? I had the control arm off, working on the bench... the things just do not want to come out. I ended up cutting it up with a sawzall and still had to pound the thing out with an air chisel. Dealerships won't replace the bushing because it takes too much effort to get it out.
The replacement OEM LCA with the bushing installed is around $350 if I recall.
Yes, it's a sht design. The 48655-60010 bushing is in the frame, not in the control arm. I'd also buy new bolts and nuts in case you have to cut them. And there are two-two spacers as well 90560-49001. Also don't forget new castle nuts and cotter pins for the lower ball joints (those doesn't come with the control arm assy)So if I want to refresh all of the lower control arm bushings, all I need to buy is the whole arm (48640-60010, and 48620-60010, then 2 of the 48655-60010 bushings?) Yes, I know I can just buy 555 ball joints and save a little money. But the whole arm comes with one bushing (front) but does not come with 48655-60010
90171-18003 and 90252-04009
I have a leaky lower ball joint and I’m still trying to decide whether I should replace my entire control arms or just do the new ball joints and new bushings. It seems either way I will have to get the #2 lower bushing out of the frame. Is that correct?
Yes, correct. I’d get the new LCA, it’s not that expensive (in land cruiser world at least)
NoThat’s what I’m leaning towards so that I get the OEM ball joints. And adding up the cost of the LBJs and the bushings it’s not too much more expensive to just get the entire OEM control arms. Considering they lasted 190k miles before they went out, not a bad investment. Does the OEM LCA come with a replacement bushing no. 2?
forum.ih8mud.com
Around $170 total from Cruiser Outfitters to refresh one LCA, which includes new 555 LBJ and new OEM Toyota bushings for the LCA and frame. Cost for a new OEM Toyota LCA is $350 + $65 for frame bushing = $415. And no, a new LCA does not come with the frame bushing (no. 2), so you have to buy that bad boy regardless of which path you choose.That’s what I’m leaning towards so that I get the OEM ball joints. And adding up the cost of the LBJs and the bushings it’s not too much more expensive to just get the entire OEM control arms. Considering they lasted 190k miles before they went out, not a bad investment. Does the OEM LCA come with a replacement bushing no. 2?
$170 vs $415 was a no-brainer for me, but to each their own.
Yes, that AC drip also caused my frame passenger sway bar bracket to shear off the frame on the same trip that my ball joint and tie rod boots sprung leaks. Bootleg design.I think the difficulty of getting the passenger side one out vs the driver was based purely on that A/C drip line making the passenger side a lot more "stuck" in there.
I had a bad lower ball joint, so I bought a Beck Arnley LCA form Rock auto for about $100. Beck Arnley stuff is almost always OEM parts in a different box. This thing looked absolutely identical to the one I took off, minus the bad ball joint of course.
