Hmm. They're supposed to ship with them. My apologies for those of you who haven't received them.
MC Designs Offroad Quik Hinge Installation Instructions:
Note:Small hands (kids or willing wife) and 12mm ratcheting boxed end wrench will prove helpful with upper A-pillar half removal and installation. Under dash clearance is very tight.
Tools: 12mm shallow socket and ratchet work well for inside lower A-pillar halves and exterior fasteners.
If doors have limiting straps or slides, remove pin from door half.
Remove from door half of factory hinge. Retain factory bolts for reinstallation.
Remove factory hinges. Top A-pillar halves are difficult to access and may require temporary headlight and ignition switch removal.
Note: It may also be good to disconnect the battery as your metal wrenches may contact under dash electrical components. Retain factory bolts for reinstallation.
Install Quik Hinges with longer hinge joint bolt at bottom hinge position, shorter bolt hinge assembly at top hinge position. This allows for ease of door alignment when reinstalling doors equipped with Quik Hinges.
Loosen hinge security nuts to allow free hinge movement.
Attach doors to door halves of Quik Hinges.
Ensure limiting device lines up with door without binding. Insert limiting strap pin.
Wait to tighten all fasteners until proper door alignment is reached.
Tighten fasteners as directed by FSM.
Installer may desire silicone seal around A-pillar half at exterior of A-pillar through hole.
Reinstall any removed electrical components and reconnect battery.
To remove door with Quik Hinges, pull limit strap pin and two security nuts per door. With door open, lift off and stow.
Reinstall in reverse order.
*Also available here*
Quik Hinges Installation
