Replacement Keys
Castle Rock, CO
Looking to make a set of replacement keys (78 fj40 main key and barn door). I live just south of Denver and would like to know if anyone could recommend a place that carries blanks. I checked the dealer at Go Toyota on Arapahoe and was out of luck. In fact they were kind enough to try cutting a key from the only set I have, unfortunately the stock may have been thicker? It did not work in either door/ignition and they didn't charge me the five bucks they quoted.
Thanks in advance and Merry Christmas,
Joe
I literally just picked my keys and lock up from Buffalo Lock and Key in Boulder this afternoon... I had some Toyota blanks (from Toyota and SOR), but they cut one using their own blank anyway. Mine is a '74, so the keys are likely a bit different, but if they had mine, they're arguably a bit more likely to have yours.
the front door and ignition keys are pretty standard. Think i even got some cut at wal mart.
the rear ambulance door is going to be harder to find. there are a couple online sources for these keys. Search this forum to find more info on that.
I've also heard that you can take a longer key and chop the length to get a key that will work in the lock.
I was able to take my door tumbler to a lock smith, an they were able to cut new keys based on that. Not sure there methods, but my keys work well in there intended locations.
I got mine made at Ace Hardware - they had the proper blanks, a few years ago, at least
but originals are available from the dealer if you know your key or cylinder number, blanks are available from Specter Offroad
I learned from a strange experience with my 80 pickup. People in Japan don't steal cars so much and back then Toyota didn't understand the American culture of; what is yours is mine if I want it. Toyota only made a handfull of lock and key combinations. I would bet that a good locksmith could adjust the keys and locks to work from a common key on Fj40s.
Late one night I heard my pickup fire up and drive down the alley, without me in it. The 20R was nortorious for exhaust leaks at the bottom of the manifold at the pipe. Anyone who ever owned one knows what they sound like. Anyway, it woke me up and I watched it drive away at about 2:30 AM. A few minutes later a cop rolls up and he says he thinks they have my truck surrounded at a crime-in-progress a couple miles away in an apartment complex. We could hear the helicopter and listened to the radio chatter. Nope, wrong Toyota.
So I go back to bed, really agitated, and wondering if it was to late to drink, and suddenly I hear my truck roaring back up the alley -- the radio was blasting away which is what helped make the roar. Got dressed, grabbed a ball bat and ran outside to find no one, anywhere. Dang it ! The hood is warm. What the hay? So I try the driver door and it was locked. Locked. Stuck my key in the door, opened it and looked around, curiously, and noticed that all my spare change in the spare change holder was still there. All $1.82 of it. Hmm, ghost riders?? I don't think they are interested in spare change but, who's to say. Put the key in the ignition, turned it, and before the starter kicked-in the radio blasted me with some heavy metal crapola that I really dispised back then. Still do dispise it... So I ran back indoors to call the cops, one more time. The same guy returns and he was just as befuddled as I. He Radios in and then he learns that my truck had just been used to rob a gas station not to far away. The attendant got the discription and plates
The next day I asked about a key and lock change at the Toyota dealer and that is when I learned about the politeness of the Japanese culture.
Thanks everyone. I will make a few phone calls tomorrow morning. I appreciate all your help.
My ignition key was more worn down than that. The PO told me he had a big key ring hanging off it when he had the truck, and because I had to jiggle the key just so to get it to turn correctly, I thought the cylinder was shot. I took the key to a local lock shop, and 20 minutes later had two new keys that worked like a dream, no jiggling necessary. A little lubrication in the cylinders, (ignition and side doors), also helped. Good luck!
Just have to find a good old-school locksmith , I've got a guy local here that can re-key locks and make keys for almost anything . It's fun trying to stump him but so far he knows exactly what application every key or lock I've taken in there fits , so far .
Gotta hit him up with the fuel door and rear amby doors soon.
Sarge
Bumping a old thread.
Im after another key for my 42. The guy at home depot said his "machine" could copy it and its a match but its too thick and wont even fit in the door or ignition too wide. The cut matches perfectly. How do those eBay blanks work out for anyone else? I mean for $5 that they are.
Just a FYI i stopped at Lowes and key blank "30" works perfectly!!!! Its a bit longer 1/2" on the end but worked perfectly!
thats crazy.!
I think its about 32 different key cuts up till 1990 ish. I can pretty much open and start any old Toyota with the keys from my other cruisers.
Picked up a 40 last year with no keys, not a problem......use one of mine and it fired up(after we changed the 10 year old gas) took code to the dealer, he cut me new keys(they are the more modern fj60 style with the plastic)
looked(and bought) at a 40 in Seattle way back, seller called to say he was running late but to check out the 40....I did, even had it running when he got home ;)
my old Toyota parts guy once cut me a key that would work on both my 82 fj40 and 86 fj60, both in the doors and ignition.
More than once I've Turned off Cruiser and Toyota headlights... key almost always works. My worn door key also makes a good pick... I've opened many a lock with it. (Glad I'm one of the good guys). I've even passed the 17 legal page RCMP record check... used to have a key for the station.
