Removing valve cover.
About to fit up my turbo ect and need to fix my leaky valve cover gasket first.
Can it be done without removing the top half of the manifold?
I've got a complete inlet manifold gasket set and was going to do the phh and fuelfilter while I'm at it but didnt want to make any more work for myself thN needed..a link to a video would be awsome or any other help apreciated.
Cheers Dale
I have a regular old 1fz-fe without turbo. My valve cover gasket can be changed by removing the air intake. The fuel filter is located under the intake manifold and can be done without removing (need kid sized hands), and the phh is easily accessed by the side of the engine block near the front drivers side wheel well. If memory serves me correctly, you may need to take the starter out to access the phh better.
Only have to remove the throttle body, but DON'T UNHOOK THE CABLES. it saves time not doing it.
The fuel filter and PHH are as stated above.
Be aware of the heater valve and hoses. They may be brittle and you have to pry on them to go in/out.
Also do spark plug tube seals, pcv grommet, distributor o-ring, plugs and wires, pcv valve and hose, as well as the throttle body hose and any vacuum hoses at the same time.
I did the three amigos (PHH, No1 Bypass and the Fuel filter) a few months back. Pull the drivers side wheel and life is so much easier. I was changing my starter motor but I can't remember how much that helped. PHH is a royal pain in the arse. The No1 bypass hose is almost as bad but you need to pull the throttle body. With the throttle body removed, change the valve cover gasket. Fuel filter was the easiest of them all. Step 6 will be a sweet moment....:flipoff2:
Thanks guys.
Had a bit of medical issue and ended up in hospital so I havnt done the job yet.
I had a spare valve cover so I got it ready.
Coil over plug conversion fitted and 10ans fitted for catch can.
How do you get to the two bottom throttle body bolts.
Thanks guys.
Got any info on the coil over plug conversion? What is needed to do this? Parts list?
Cheers Dale
Just took my VC off. Don't need to touch manifold. You can get it off without removing throttle body, but you're not likely to get it back on that way without screwing up the spark plug tube seals or shifting the VC gasket, so just remove it beforehand.
PHH doesn't require manifold or starter removal, or wheel removal or even a jack. (Ask me how I know.) Run the 52-inch bypass around the MC to save a few hours. Jack up and remove wheel if you can, for ease of access. Not that it will be EASY.
Haven't done fuel filter but there's a thread right now on that...
Teaser thread!! Haha. I think we all want to see the details of this and the conversion!
Great Advice!
