I dropped the support to lower everything a couple of inches. I used a swivel socket.Bolt #5 is giving me a hell of a fight. Wobble, extension, and just about every different combination of 17mm sockets I have and I can't seem to get it to move. Haven't dropped the trans support yet... maybe that'll help. I will have to do that for #6 for sure. No room to squeeze a tool in between tcase and floorboard.
strange, I loosened my #5/#6 bolts with ease and without lowering. My old T-Case isolator must have been truly collapsed. Think I used a fixed shallow socket with two extensions and a wobble, 3/4" drive, Try PB blaster for a few days (providing you can spray up in there)Bolt #5 is giving me a hell of a fight. Wobble, extension, and just about every different combination of 17mm sockets I have and I can't seem to get it to move. Haven't dropped the trans support yet... maybe that'll help. I will have to do that for #6 for sure. No room to squeeze a tool in between tcase and floorboard.
Dang - so it was removable by hand? Mine is quite snug. I tried long reach needle nose plyers wrapped in electrical tape on opposing ridges but could only get it to minimally budge. Was thinking the same with some vise grip style, but getting the vise grip handle into the house is quite challenging. Could only get my smaller pair in there.
Based on your profile name I get the sense you’re not stateside so Harbor freight is not an option for you, but this is the set I used (as per the above)Can not for the life of me get #5 out. normal UV joint style socket setup wont work. No space. Looking to get a 17mm swivel socket. Otherwise any suggestions?
Interesting, I know I did not do that. Noted for next timeAnother Mud member posted that it's a good idea to put your transmission in neutral before you lower the trans/TC assembly and detach the TC, to avoid stressing the cable that controls shifting. I think that's important and often overlooked.
Nope not stateside. I'll see what I can find here in Australia that's similar.Based on your profile name I get the sense you’re not stateside so Harbor freight is not an option for you, but this is the set I used (as per the above)
Drop the trans crossmember, it’ll lower the whole assembly 3-4 inches and give you the access you need.Can not for the life of me get #5 out. normal UV joint style socket setup wont work. No space. Looking to get a 17mm swivel socket. Otherwise any suggestions?
Thanks. Was planning to do that for the one at the top that you can't see. I've found a used TC so will need to get the old one out now for sure. Internals are toast.Drop the trans crossmember, it’ll lower the whole assembly 3-4 inches and give you the access you need.
