Day 3: I am doing this in very small parts just when I have time. Today I was able to remove the front driveshaft from the TC. Again took a lot of wiggling but eventually came off. I then removed bolt 4. I am having terrible luck with every bolt/nut so far. They are incredibly seized. I was able to break it free using a 5 in extension and a breaker bar. I then removed the speedometer cable and the electronic diff lock connection. The speedometer cable connection blocks the access of bolt # 5 so I had to remove the entire cable. This was a pain and I accidentally broke the plastic bracket that connects it to the TC. Not a huge deal as I am sure I can secure it some other way. Also, in case this helps anyone. Be careful not to put too much force on the transmission pain when removing bolt #4. It can be easy to use as leverage.Day 2: I didn’t have as much time today but I did manage to get the front drive shaft nuts removed. Didn’t have time to take the drive shaft off. I’ll be doing that tomorrow as well as hopefully bolts 4 and 5.
Pro tip: when removing the drive shaft of the bolts are difficult to reach out the TC in neutral as well as the transmission and slowly roll the car. Then put the parking brake on and the put the TC in gear. This will make the bolts very easy to access. I am embarrassed to say I fought with extensions before realizing this.
Tomorrow I’ll be doing bolt 5 and the remaining bolt with the exception of 6 should go very fast. I will probably drop the TC Saturday. I obtained a second floor jack and will hopefully have a buddy help me. I don’t want to spend the money on a transmission jack so I am hoping we can just guide it down.
I attached a picture. Red is how the speedometer cable connection blocks bolt 5. Green is the diff lock motor. I haven’t seen where the cotter pin connection is. It was reference earlier in this thread. If anyone can tell me how to find it I would appreciate it.
