removing steering column
SoCal
Did I read the manual right? To pull the steering column you disengage the steering box & pull the whole thing forward through the firewall? If so, couldn't they have made it more difficult with just a little more thought put into it? Oh, I have a '74 FJ40.
Vic
Redlands, CA.
Older steering boxes had a worm gear directly connected to the shaft; you had to take the cover off the front of the box and pivot the whole thing up and pull the shaft out the front.
http://www.sor.com/sor/cat098.tam?xax=26717&page.ctx=cat098.tam
Well, now I'll have to read the manual, which appears to be factory, again to make sure I did so correctly. I hope y'all are right but when I loosened the clamp the steering shaft sure didn't want to move backwards. May be that my inexperience with this truck is showing. Now that I think about this, it might be that the manual covered a range of years, from like 1972 to 1974 and what I read was for the 1972 vintage FJ40. Sure hope so.
From Toyota Land Cruiser Chassis & Body Repair Manual, Toyota Motor Sales Co., Ltd., Export-Technical Department:
p. 6-17:
12. Using Pitman Arm Puller, 09612-55010 remove the pitman arm.
13. Remove the steering gear box bracket cap, and then lifting the steering gear box and mast jacket, take them out through the engine compartment.
So, I repeat: Huh?
This is the only part of the manual so far as I can tell that comes close to removing the column. Perhaps the translator lost a page or two and it never made it into the "finished" manual. It still doesn't make a lick of sense.
HawkDriver said:
Sorry, I just busted up about pulling it all through the front. Is there no humor in that?
Thanks Busta! fo that little bit o knowledge. ;)
Yep you can just call me mr. old school, even though my cruiser's got 12 years on me.
Its a PITA and a harpoon of death cocked for your heart, glad I got a collapsible shaft now :banana:
i laughed hawk, ha ha
This is one for the books guys. Vic called me on this, and from the way he explained it to me, it really sounds like someone retrofitted the pre 72 steering box TO HIS STOCK 74 column!
He's got the column with the ignition on it and the upper support bearing, and the column tube ends at the firewall, but the steering shaft continues straight on down into the steering box............. without a sheath over it! I've asked him to take a pic to confirm this.
So the predicament is that because of the press fit between the shaft and the upper support bearing, he can't just lift the column tube up thru the cab like you could with a stock 74 setup. By the same token, with the large flange integrated into the bottom of the 74 column tube, he can't just pull the box out thru the engine compartment like a pre 73.
Truly a predicament. Without seeing an actual pic of the PO'S POS booty fab, I didn't want to go out on a limb and recommend a specific procedure. I'm thinking that IF the PO got a pre-73 shaft snugly into the upper support bearing of a 74 column, it may not be as tight a a correctly fitted stock 74 shaft would have been, and that he could put the locknut back on the end of the shaft to protect the threads of the shaft and then start tapping down on the end of the shaft with a brass hammer while pulling up on the column tube to release the shaft from the support bearing.
Hope I explained this ok.
What a mess. The ignition/turn signal assembly separated from the upper support bearing in the process of trying to "gently" drive it off. Just as well b/c I destroyed the bearing getting it off the steering shaft. Didn't do the shaft any favors either. But now the shaft comes out of the FRONT of the truck, that's for sure. The question now is whether to get a new bearing and put it all back together the way it came to me or spend the $ to install what I understand is correct for a 74FJ40. If this steering setup is otherwise safe and secure I'd just as soon spend the money on something else. Any thoughts?
Vic
Redlands, CA.
Vic, my .02 on this is get the stock stuff for the truck. The older steering boxes are ok, but they are a little weaker, and wear out faster than the newer ones. Point 1: longevity
Point 2. There are enough guys out there on this board alone who've gone Saginaw or mini-truck ps on their rigs that someone in the wanted section oughta be able to get you a core for not much more than the ride.
The stock column isn't as much of an issue as the turn signal switch and ignition. If you've already got good ones of those, columns can usually be had fairly cheap without those two items on them. I would be happy to sell you one of those if you don't have luck finding one on the board.
And of course I'd be happy to rebuild the steering box for you, just don't need to charge you for a core if you can find one here.
BTW, the pics you brought over ABSOLUTELY matched my description.;)
Mark, we can discuss more next time I'm out your way. My preference, if affordable, is to get back to what it should be, not what it is now. If nothing else, I think I'd like to have the pleasure of making a wind chime out of that steering shaft!
:eek:
Somebody else might actually need that steering box.
I'm sure I can find you some other LC part that would make a good wind chime.;)
