Rich, do you have drawing you can post to show the difference in pinion angle if rotated around the center or just put in the way the instructions call for?
I personally am not comfortable suggesting people set there trucks up with an alignment that is out of spec. .
FWIW: Here's my situation...
I"m at 23.75" hub to flare with the rear just slightly over that, maybe 24"
I'm running OMEJ fronts and heavy rears.
I have Slee Caster Plates and a DC driveshaft as well as adjustable rear uppers
The truck drives really straight and there is no Vibration or Grrrr...
I need to confirm, but I have a Caster reading on the truck and it's at 3.5, 3.0...just making sure that wasn't before the lift. The dates seem to coincide correctly...but I'll confirm.
is that before or after 4 pitchers of oatmeal stout?![]()
those readings would be really high from all the trucks I've done. I'd think more in the range of 1.0-1.5*.
Why? He has less lift than the Slee 4" which should mean those plates have rotated the pinion further down and caster should be greater, not lesser. By your numbers, Slee plates on a Slee 4" spring unweighted (hub to flare of closer to 24.5") would mean near zero caster. I'd say his numbers make perfect sense for the lift height.
I messed up....It was 3.11 and 3.15...not 3.5 like I originally stated, I'm apparently dislexic
Here's the numbers from my old 80 with the 4" springs, measurements and caster correction by way of Slee Arms.
Bone stock 80:
Caster
L: 3.0 R: 2.7
Hub to bottom of flare
F: 19" R: 19.5"
Lifted no caster:
Caster
L: -2.3 R: -2.8 change of about ~5ish
F: 24" R: 24 3/4"
Lifted w/arms:
Caster
L: 4.4 R: 4 change of around ~7ish
F: 24 1/4" R: 24 1/4"
Sooo...Slee Arms and 4" springs = 4.4 caster
Slee Caster plates and J springs = 3.1 caster
unfortunately I don't have a Before reading on this cruiser, but I'm only ~.5" off on height...maybe initial caster was better? I dunno...I drives great and no vibes lol.
you got about 5.4* of actual correction from his plates which is where I thought they would be. The hub/flare measurements just seem to be a little off from all the trucks I've seen. You're not running a body lift are you?
Well all the before measuremnts were from my old cruiser. This is a different 80 series and I don't know the original measurments on caster.
No bodylift, but again...I messed up(picked a bad day to stop sniffing glue)
22.75 front
23 rear
Which makes more sense now. i went outside and measured again. So 1.25" lower in the front than the 4"
because he has more height on his truck than mine and others who have used caster plates. Confirmed by his hub/flare measurement.
again
IT HAS NOTHING TO DO WITH THE SPRINGS ADVERTISED LIFT MEASUREMENT
it's the final height that determines caster need!
My point is a straight 4" Slee lift with a properly aligned DC shaft keeps caster in spec, does it not?
So if you have less lift, then you should be in spec with those same caster plates,
Your expected measurements being out of spec on the low end make no sense on a 3.5" lift
